Posted July 8, 20213 yr comment_624722 I have now removed the horn relay from way way up top. not seen in photo.. now im trying to figure out what the other ones are.. i know one is fan, one is defrost one is wiper.. whats the other and which is which.. the images in the fsm are totally wrong..can ya help me out..?? thanks Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/ Share on other sites More sharing options...
July 9, 20213 yr Author comment_624771 can anyone tell me what these relays are??? Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624771 Share on other sites More sharing options...
July 9, 20213 yr comment_624787 Did you take apart the horn relay? You never showed what was inside. Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624787 Share on other sites More sharing options...
July 9, 20213 yr comment_624788 The FSM sometimes has errors, but to say that all of the images are wrong seems off. What is the build month of your car, you may want to download the 1973 or 1975 manual and see if the relay panel images are closer to what you have. Edited July 9, 20213 yr by 240dkw Added 1975 Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624788 Share on other sites More sharing options...
July 9, 20213 yr comment_624790 Unplug them and see if the shape of the plug and the wire colors match the drawings. Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624790 Share on other sites More sharing options...
July 9, 20213 yr comment_624791 Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624791 Share on other sites More sharing options...
July 9, 20213 yr comment_624794 You could also unplug them, one by one, and see what stops working. Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624794 Share on other sites More sharing options...
July 9, 20213 yr comment_624797 Sometimes you can find these numbers on the internet. http://www.carpartsmanual.com/datsun/Z-1969-1978/electrical/electric-unit-switch/section-2/240z-260z-(from-aug-73) http://www.carpartsmanual.com/datsun/Z-1969-1978/electrical/electric-unit-switch/section-1/240z-260z Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624797 Share on other sites More sharing options...
July 9, 20213 yr comment_624800 Bless you Zed... Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624800 Share on other sites More sharing options...
July 9, 20213 yr Author comment_624821 Yea. I saw the wiper relay. It was the others I was after. Horn relay is a bitch yo get out. They stuck it way up there. It was like dust inside. As below. Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624821 Share on other sites More sharing options...
July 10, 20213 yr comment_624825 Looks like it was on the bottom of a lake...pfff... for years.. Hey Shawn.... When your car works again you have to send Zed a big whipped cream cake! 🙊 Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624825 Share on other sites More sharing options...
July 10, 20213 yr Author comment_624843 Car runs good and most stuff works ok. Water leaked through front window. Not submerged under lake. Link to comment https://www.classiczcars.com/forums/topic/65577-74-260z-what-are-the-relays-in-photo/#findComment-624843 Share on other sites More sharing options...
