Hello all, I’m in the process of installing my doors and it seems I have lost the compression washers. Does anyone know what size washer is needed or where I can purchase a set? I found a used set of 5 online, but I need 12.
https://www.classiczcars.com/forums/topic/65583-door-hinge-washers/
Those thick washers are available from Belmetric
Would you happen to know which specific washers those would be? I just looked through the site. I’d gather it’d be either the thick washer or the sealing washer. I’m not 100% sure.
