Found one of the old MM threads.  Post 36 on.
Thanks ZH, just bought OEMs from NissanPartsDeal for $48 each. Expensive but I’m not in the mood to modify and have more headaches.
https://www.nissanpartsdeal.com/parts/nissan-insulator-mount~11220-n3300.html
Whoever has the middle Vision is the coolest hands down or up. Depends on your riding. Helmets and pads are life changing nowadays. I'm scarred from ear to toes from those damn things. Motorcycles were way worse.
Personally I like "kick and goes" now. They're great for the mailbox.
We never wore helmets...you might get beat up if you did. Today it’s mandatory. We had a 13 year old hit his head skateboarding a few years ago in my neighborhood. He died in the Ambulance due to being intimated into his stomach. Very sad. We know the family. His family set up a foundation.
https://www.doitfordrew.org
Plywood and steel wheels purloined from street skates in the early sixties. Sixty years later a few of the old memories (scars) remain and remind me of the good old days of adrenaline fueled afternoons and the painful recoveries.
Mark you were the pioneers. The Lewis and Clark of skating.
Mark I figure there's nothing you haven't done or have happened to you. Your eyes tell a story I only wish I could see. Kathy's do too! It takes one to know one just scratches the surface. I'll always be thankful you two are part of my life.
You've done a lot of living my friend. :beer:
Charles, @Patcon you are another of my friends that "ain't scared" of nothing. I can't imagine you killing a snake. You'd pick it up and see how unique it is then let it go on it's way. Your the guy on TV shows.
Edited by siteunseen
We may have been pioneers but we were crazy to do that. Steel wheels on asphalt and concrete had little to no cornering capability or control. We thought ourselves to be bulletproof back then but we were little more than passengers on a gravity express. No slalom course, just a schuss to see if we could stay on till the bottom of the hill. Frequently, we didn't. The adrenaline addiction stayed with me for years
A few years back @Captain Obvious turned my old skateboard veneers into a shifter knob. It’s cool to keep using the old board, lots of memories with it….
Reduce, reuse, recycle I guess 🙂
The new one is slightly larger, so it fits my hands better…
Just my $0.02 worth regarding mounting the intake and exhaust before  you put the engine in the car. I have never found it to be a fun thing to do bent over the fender trying to get one of the exhaust bolts/nuts on right. For me it's much easier to do it on a stand where I can rotate the engine to gain the best possible angle (notice best possible not the best angle). In the course of a race season I might have an engine in/out 3-4 times. Even a single swap is done the same way.  Blew  head gasket at Summit Point in May, swapped in the back-up motor and am waiting on a new head gasket so I can do The Glen with a few more HP in October.
Edited by gnosez
So, I have already mounted my intake and header. I have one small problem. One of the upper intake bolts is partially stripped. It will lightly tighten but when I torque it it spins. Can’t spin by hand. So I can try and tap it bigger not or wait and see if it holds. It’s my fault it stripped. It wasn’t sitting flat when I originally mounted the intake manifold the bottom was hanging up on part of the header and was off flat by 1/8” of an inch.
Question2: Do I need a new transmission mount ? Again is it one of those items that should just be replaced. I found an OEM one for $88 for aftermarket for about $43. Not sure if there is a difference like the engine mounts.
