December 3, 20213 yr comment_632602 On 12/3/2021 at 10:04 PM, Patcon said: Check valve lash. You sound like you have a noisy lifter or two. I don't think its an exhaust leak... I agree. It's a "clickity" sound not the "tangity" sound from exhaust leaking. A short piece of hose for a stethoscope would be helpful locating the source. Car looks great! It's been enjoyable for me reading your thread. You know what you wanted and now you have it. Well done! Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632602 Share on other sites More sharing options...
December 3, 20213 yr comment_632603 Read #6 from @Diseazd Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632603 Share on other sites More sharing options...
December 4, 20213 yr comment_632612 i'd have to hear it in person to decide if it's valve noise or just normal injector noise. In any event, the car looks great. I'm so happy you're getting some time behind the wheel! Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632612 Share on other sites More sharing options...
December 4, 20213 yr comment_632620 Your car looks great! Congrats on the progress. I just hear normal injector tick, not exhaust leakage or valvetrain noise. Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632620 Share on other sites More sharing options...
December 4, 20213 yr Author comment_632631 Thanks for the tips. I have only done a cold valve adjustment so I need to get it hot and do another adjustment . The engine has less than 30 mins run time on it so I’m slowly exercising it. Yesterday the oil pressure gauge looked low to me. The scale on the gauge goes 0-90psi. The needle was sitting around 30psi. Not sure yet if this is correct. Could be the sensor which is a ZX version (2 spade connectors vs 1 bullet). I made an adaptor plug to got from bullet to spade and left on spade fitting empty. Maybe that’s the issue. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632631 Share on other sites More sharing options...
December 4, 20213 yr comment_632632 On 12/4/2021 at 1:59 PM, Av8ferg said: Yesterday the oil pressure gauge looked low to me. The scale on the gauge goes 0-90psi. The needle was sitting around 30psi. On idle the pressure seen on the meter can be very low.. It's a known problem.. To be sure you can always look under the oil fillercap during idle, but look out.. the oil can jump out the opening a bit.. If the camshaft is oiling good the rest is also good. Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632632 Share on other sites More sharing options...
December 4, 20213 yr comment_632634 If you have 30 psi at idle, I would consider that very good Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632634 Share on other sites More sharing options...
December 4, 20213 yr comment_632659 Pressure should rise with RPM. You might rev the engine and see what the needle does. The oil pressure gauge and sensors are known for their inaccuracy on these cars. Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632659 Share on other sites More sharing options...
December 4, 20213 yr comment_632666 You can run a gauge on the end of a couple feet of hose under the driver's wiper and watch what it does while you're driving. Thank you to @FastWoman for that trick. Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632666 Share on other sites More sharing options...
December 5, 20213 yr comment_632688 On 12/4/2021 at 11:33 PM, siteunseen said: Thank you to @FastWoman for that trick. There is a name I haven't heard in a long time! Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632688 Share on other sites More sharing options...
December 5, 20213 yr comment_632703 On 12/5/2021 at 3:33 AM, Jeff G 78 said: There is a name I haven't heard in a long time! This was one of my first reads when I joined this forum. There's a lot of names in here I haven't seen around anymore, Z Train, Z Curves, Coyze... Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632703 Share on other sites More sharing options...
December 6, 20213 yr comment_632763 On 12/4/2021 at 1:59 PM, Av8ferg said: Thanks for the tips. I have only done a cold valve adjustment so I need to get it hot and do another adjustment . The engine has less than 30 mins run time on it so I’m slowly exercising it. Yesterday the oil pressure gauge looked low to me. The scale on the gauge goes 0-90psi. The needle was sitting around 30psi. Not sure yet if this is correct. Could be the sensor which is a ZX version (2 spade connectors vs 1 bullet). I made an adaptor plug to got from bullet to spade and left on spade fitting empty. Maybe that’s the issue. Sent from my iPhone using Tapatalk Oil pressure rule of thumb is 10lbs for every 1,000 rpm. So ten pounds at idle is plenty, at 7,000 rpm 70 to 80 psi is fine. A good quality (read Stewart Warner) mechanical gauge is best. For the diamond pleated covering, a heat gun helps to get it formed and stretched over the irregular shapes of the tunnel and floor. Link to comment https://www.classiczcars.com/forums/topic/65616-putting-in-a-replacement-l-28/?&page=33#findComment-632763 Share on other sites More sharing options...
