July 20, 20214 yr comment_625424 On 7/19/2021 at 4:25 PM, psdenno said: I removed the rear bumper from my 240Z to replace the rubber trim pieces on the bumper ends and over riders. The 50 years of rust seem to have bonded the over rider attachment nuts to the studs. I've soaked them with multiple applications of PB Blaster for a few days, and they're still rusted on tight. Any suggestions for a better brand of penetrating oil? I did the front bumper rubber a couple months ago and all went much easier. As mentioned, there are myriad brands of penetrating concoctions. I’ve had good results from PB Blaster, Kroil, Gibbs, and Mopar heat stove lube (for freeing up rusty heat stoves on carburetor choke assemblies). Heat will go a long ways towards freeing up rusty fasteners. I have also found that a sharp rap in just the right spot with a drift and hammer will break the bond at the threads. Good luck and I hope you win. Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625424 Share on other sites More sharing options...
July 21, 20214 yr comment_625472 @psdenno Kroil by KanoLabs It actually is a class above everything else I’ve used in 60 years. For the average car guy one 10 oz spray can will last several years. Granted it is a little pricey - but well worth spending the extra few dollars. I always used to order it direct from Kano Lab’s - but now I see they are working though sales outlets and distributors (and it has gotten more expensive as well) https://www.kroil.com/where-to-buy/ Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625472 Share on other sites More sharing options...
July 21, 20214 yr Author comment_625476 On 7/21/2021 at 9:53 PM, Carl Beck said: @psdenno Kroil by KanoLabs It actually is a class above everything else I’ve used in 60 years. For the average car guy one 10 oz spray can will last several years. Granted it is a little pricey - but well worth spending the extra few dollars. I always used to order it direct from Kano Lab’s - but now I see they are working though sales outlets and distributors (and it has gotten more expensive as well) https://www.kroil.com/where-to-buy/ Thanks for the tip! Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625476 Share on other sites More sharing options...
July 23, 20214 yr comment_625541 I always use PB Blaster. Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625541 Share on other sites More sharing options...
July 24, 20214 yr comment_625645 I might be wrong, but I’ve come to think that some types of rubber do not like what is in PB Blaster. I think it makes it swell, just a thought. I now just try to avoid getting it on rubber and plastic or wipe it off if I do.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625645 Share on other sites More sharing options...
July 29, 20214 yr Author comment_625913 After a week and a half of applying three different brands of penetrating oil and repeated attempts of using a torch to heat and expand the nut on the bumper over rider, the 50 year old bumper wins. This morning, I put it in the truck, drove to a machine shop, dropped it off and will see what their magic can do. Thanks for all the suggestions along the way. Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625913 Share on other sites More sharing options...
July 29, 20214 yr comment_625914 Just curious did you try the Kroil? Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625914 Share on other sites More sharing options...
July 29, 20214 yr Author comment_625917 On 7/29/2021 at 5:51 PM, Yarb said: Just curious did you try the Kroil? No, in spite of the solid recommendations. Not available locally and only to Business Members through Amazon. So, I used what I could get and didn't accomplish the task. The machine shop I dropped it off at today has a "home brew" penetrant. The other alternative was to just cut the over rider mounting stud off below the nut after raising the nut as far as it would go. I prefer to keep the original over rider if possible. New rubber trim is on hand and ready to install. Front bumper and over riders were much easier. Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625917 Share on other sites More sharing options...
July 29, 20214 yr comment_625919 On 7/29/2021 at 6:36 PM, psdenno said: No, in spite of the solid recommendations. Not available locally and only to Business Members through Amazon. So, I used what I could get and didn't accomplish the task. The machine shop I dropped it off at today has a "home brew" penetrant. The other alternative was to just cut the over rider mounting stud off below the nut after raising the nut as far as it would go. I prefer to keep the original over rider if possible. New rubber trim is on hand and ready to install. Front bumper and over riders were much easier. I wonder if that's a California thing with Kroil. I ordered it from Amazon in the past without being a "Business Member", and I had no problem with putting it in my cart today. Do you have any friends in Arizona who could order it for you and smuggle it across the border in case you need it in the future? 😉 Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625919 Share on other sites More sharing options...
July 29, 20214 yr Author comment_625920 On 7/29/2021 at 6:56 PM, SteveJ said: Do you have any friends in Arizona who could order it for you and smuggle it across the border in case you need it in the future? 😉 Good suggestion, but prefer NOT to do 5-10 years in the Greybar Hotel for smuggling petro chemicals into the Great State of California.😎 Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625920 Share on other sites More sharing options...
July 30, 20214 yr comment_625961 https://youtu.be/EoIo6z5qg9g Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625961 Share on other sites More sharing options...
July 30, 20214 yr comment_625965 On 7/30/2021 at 6:07 AM, bartsscooterservice said: https://youtu.be/EoIo6z5qg9g I like it! Link to comment https://www.classiczcars.com/forums/topic/65617-best-penetrating-oil/?&page=2#findComment-625965 Share on other sites More sharing options...
