Posted July 19, 20213 yr comment_625382 I have a few old broken drivers side outside door handles that are broken where the rod attaches,,, i now realize i have a broker passenger side handle.. can i use the old drivers side handles for passenger side and just put the rod on the other side of the handle that is still good??? will that work or are the handles specific to the side??? Edited July 19, 20213 yr by Shawninvancouver Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/ Share on other sites More sharing options...
July 19, 20213 yr comment_625383 Yes, you can. I used to do this all the time. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625383 Share on other sites More sharing options...
July 19, 20213 yr Author comment_625385 Perfect Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625385 Share on other sites More sharing options...
July 20, 20213 yr comment_625406 Yep, I've done this myself over the years. 🙂 Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625406 Share on other sites More sharing options...
July 26, 20213 yr Author comment_625726 i put in broken door handle from drivers side to passenger side,,,, it will technically work but half of the handle still pulls out of the door.. it wont last long.. its like a half arse handle .... im trying to jb weld it so it will work more like a normal handle.. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625726 Share on other sites More sharing options...
July 26, 20213 yr comment_625727 JB weld probably won't work in this situation. It doesn't like to be flexed. Seals holes, drill it, mill it. Can even pull on it, but flexing, not so much Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625727 Share on other sites More sharing options...
July 26, 20213 yr Author comment_625729 Bummer. So how can I fix the broken side so I can use the broken drivers side in the passenger side??? Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625729 Share on other sites More sharing options...
July 26, 20213 yr comment_625736 Those doorhandles are made of zamac.. It's a disasterous "metal" a mix of aluminium,copper,zinc.. it rusts from the inside of airbubbles that are IN the alloy.. so you can't stop the decay The ornament "Z"on the c-pillar, (air outlet), are also made of that stuff.. a restorers nightmare! 😞 Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625736 Share on other sites More sharing options...
July 26, 20213 yr comment_625737 Those doorhandles are made of zamac..At least it starts with a Z! :p Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625737 Share on other sites More sharing options...
July 26, 20213 yr comment_625738 Buy another one Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625738 Share on other sites More sharing options...
July 26, 20213 yr comment_625740 45 minutes ago, Patcon said: Buy another one There are both very affordable reproductions and not that much more expensive OEM ones available from all the usual vendors. https://www.thezstore.com/page/TZS/CTGY/classic02o02e01 Edited July 26, 20213 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625740 Share on other sites More sharing options...
July 27, 20213 yr comment_625777 The topic is.... Can i use broken drivers side door handle on passenger side?? BTW... have we all read this correctly? you can't use a broken one! On any side!! (Yeah i know i'm what we call overhere a : "muggezifter" ... No translation possible.. let say someone who is very critic on his (or sometimes other peoples) work.. 🙊 Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/#findComment-625777 Share on other sites More sharing options...
