Posted July 20, 20213 yr comment_625400 Im rebuilding a 5 speed from a 77 280Z and want to include the seal and o-ring on the striking rod assembly in the tail of the trans. It was clearly a leak. There is no access hole in the side of the case as shown in the service manual. How do I remove this retaining pin on the striking rod? I tried to fabricate a tool out of a small c-clamp but cannot get in there...no room. Has anyone overcome this? I hate to do this complete overhaul without this seal. Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/ Share on other sites More sharing options...
July 20, 20213 yr comment_625401 @EuroDatcould possibly help you on this one. Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625401 Share on other sites More sharing options...
July 20, 20213 yr comment_625403 This has been discussed and solutions provided in another thread, do a bit of searching. It is much trickier in the early 5 speeds that don't have the reverse lockout device. That pin is quite tight. I built a little press thingy that slips over the rod, but the easier method is to drill the case where the reverse lockout would be, use a punch to get the pin out, then put an NPT pipe plug back in the new hole to seal it. Once you find the thread and read what others have done, the solution will come to you Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625403 Share on other sites More sharing options...
July 20, 20213 yr comment_625409 Like zKars said, there is a thread that details methods to remove it. I have used a small massive hammer, one with as much weight as possible and small. Unscrew the nut until it is flush with the end of the thread. Tap it with the hammer until it comes loose. If it won't release than add heat to the striking lever area around the pin and tap it out. Don't heat the pin. You wont the lever to expand, but not the pin itself. If you damage the pin, you can still get them through Nissan or local parts store. I think the size is 9.5mm IIRC. Ask for a 9.5mm cotter pin. Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625409 Share on other sites More sharing options...
July 20, 20213 yr Author comment_625413 On 7/20/2021 at 4:46 PM, EuroDat said: Like zKars said, there is a thread that details methods to remove it. I have used a small massive hammer, one with as much weight as possible and small. Unscrew the nut until it is flush with the end of the thread. Tap it with the hammer until it comes loose. If it won't release than add heat to the striking lever area around the pin and tap it out. Don't heat the pin. You wont the lever to expand, but not the pin itself. If you damage the pin, you can still get them through Nissan or local parts store. I think the size is 9.5mm IIRC. Ask for a 9.5mm cotter pin. Thanks all. I appreciate the input, but please....tell me how a hammer is going to fit down there. I cannot remove that shaft without removing the striking lever. Catch 22. I ran out of patience searching threads but I will keep trying. Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625413 Share on other sites More sharing options...
July 20, 20213 yr comment_625415 The last thread was somewhat recent. Back around May iirc Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625415 Share on other sites More sharing options...
July 20, 20213 yr comment_625417 Google works well to search the site Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625417 Share on other sites More sharing options...
July 20, 20213 yr comment_625418 I think it's in this thread, below, somewhere. It's very difficult and the method you end up using will probably depend on your own individual skills with various tools, and knowledge of how metal things work. One key point seems to be to brace the rod by putting a solid object between it and the case, so that you can apply force without damaging the rod. Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625418 Share on other sites More sharing options...
July 20, 20213 yr comment_625419 Yoh can read this one too. Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625419 Share on other sites More sharing options...
July 20, 20213 yr comment_625426 This is how i did it, does your bolt not line up with the access hole? might have to make a little clamping tool.... Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625426 Share on other sites More sharing options...
July 20, 20213 yr comment_625427 On 7/20/2021 at 1:29 PM, SteveKinSC said: There is no access hole in the side of the case He ain't got no access hole... Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625427 Share on other sites More sharing options...
July 21, 20213 yr comment_625436 I spent hours on this trying many ideas. What finally worked for me was.... 1) Loosen the nut until it is flush with end of the bolt. 2) Heat fork...several cycles. 3) Then, I used a long 3/8 socket extension. I rested the side of the male end of the socket extension on the nut head. Then, I hit the side of the extension with a bfh until it released. To be clear...I was not resting the end of the socket extension on the nut end and reaching a hammer inside the case. The socket extension is horizontal....parallel to the transmission shafts. The side of the male end of the socket extension rests on the nut. I hit the side of the shaft from just outside of the case with a bfh...being careful to not let the extension slip off of the nut head. This is hard to explain with words so I hope I am being somewhat clear. After several solid hits, the bolt moved. Edited July 21, 20213 yr by jonathanrussell Link to comment https://www.classiczcars.com/forums/topic/65619-help-wanted-how-do-i-remove-this-shift-shaftstriking-rod-in-280z-5-speed/#findComment-625436 Share on other sites More sharing options...
