How can the dome light have an on and off position. I think when off the door pins control it to turn on. When the switch is turned on with dome switch it goes on. Ā My dome light works fine with click switch on dome light. Ā But prior to it doing that if IS off. Ā Iā€™m trying to get it in without click switch. Ā Just by door pins. Ā I have power to two of the pin wires. Ā So I tried grounding them and no change. I have an led in dome light. Does that matter??
Did you confirm that the ground is good?Ā  Did you try the key in the ignition to see if the buzzer works?
