July 23, 20213 yr comment_625576 That's how mine works. Link to comment https://www.classiczcars.com/forums/topic/65623-how-to-get-door-switch-to-control-dome-light/?&page=2#findComment-625576 Share on other sites More sharing options...
July 24, 20213 yr Author comment_625585 How can the dome light have an on and off position. I think when off the door pins control it to turn on. When the switch is turned on with dome switch it goes on. My dome light works fine with click switch on dome light. But prior to it doing that if IS off. I’m trying to get it in without click switch. Just by door pins. I have power to two of the pin wires. So I tried grounding them and no change. I have an led in dome light. Does that matter?? Link to comment https://www.classiczcars.com/forums/topic/65623-how-to-get-door-switch-to-control-dome-light/?&page=2#findComment-625585 Share on other sites More sharing options...
July 24, 20213 yr comment_625586 5 minutes ago, Shawninvancouver said: I have power to two of the pin wires. So I tried grounding them and no change. Did you confirm that the ground is good? Did you try the key in the ignition to see if the buzzer works? Link to comment https://www.classiczcars.com/forums/topic/65623-how-to-get-door-switch-to-control-dome-light/?&page=2#findComment-625586 Share on other sites More sharing options...
July 24, 20213 yr Author comment_625587 I’m pretty sure I did. When key is in I get power to the two wires but only lights up my test light. Nothing else happens Link to comment https://www.classiczcars.com/forums/topic/65623-how-to-get-door-switch-to-control-dome-light/?&page=2#findComment-625587 Share on other sites More sharing options...
