Thanks @Zed Head   Update:  I was able to push the 12mm bolt thru what I believe was gasket sealant.  For the upper 10mm,  I had an extra bolt that I ground to a point. That one pushed right thru the sealant too.  All's well in Seattle again.  Thanks much as always for the support!  JH
