July 31, 20213 yr comment_626046 And from the FSM ... Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-626046 Share on other sites More sharing options...
July 31, 20213 yr comment_626055 So if I’m reading this correctly, it’s saying that the cam cover / rocket cover works to suck blow-by gasses at full throttle through the airbox and at idle it’s done via the block breather and PCV valve.So - let’s choke get my own thinking: does this mean that blocking the block on and just using the rocker cover outlet is sufficient if you just plumb it into a tank!? Could that be the logic behind the DSI thinking on blocking them?As the captain pointed out, the bottom and top aren’t sealed from each other. So blocking the bottom one shouldn’t pressurise the crank case.But does blocking the bottom one just mean more regular oil changes required as the vapours are less effectively extracted? And doesn’t a catch tank without a vacuum mean the same thing really? Not sure about you chaps, but my oil is changed annually which equates to an average of 1000 miles per oil change anyway. Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-626055 Share on other sites More sharing options...
August 23, 20231 yr comment_656237 Bumping a super other thread to life. But I'm in the process of building a catch can setup for my Z that needs to be sealed to conform to NASA regulations. I was planning to do crankcase and valve cover to a two port can. But the above option looks like a possibility as well perhaps? Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656237 Share on other sites More sharing options...
August 23, 20231 yr comment_656246 Which option above? Whichever way you run the hoses there needs to be a connection to the intake system, if you want a sealed system. That's where the crankcase pressure goes. There's always blowby so there's always going to be pressure. The simplest method would be to maintain the stock flow paths but to extend their length to run through the catch can(s). Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656246 Share on other sites More sharing options...
August 23, 20231 yr comment_656247 Thanks Zed Head. I think I was misunderstanding the NASA CCR rules for running a catch can. Now that I am rereading, it sounds like it just needs to terminate within a can, but the can itself can be vented. I just assumed it needed to be a sealed system. I am running triple mikuni carbs so running a sealed system was causing a headache. Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656247 Share on other sites More sharing options...
August 24, 20231 yr comment_656264 Why not run the atmospheric vent from the catch can to the exhaust downstream of the header collector, using a one way check valve, like the drag racers do? Any excess vapors are drawn into the exhaust and are burned there. Edited August 26, 20231 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656264 Share on other sites More sharing options...
August 25, 20231 yr comment_656273 That is a good solution @Racer X....that requires more work Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656273 Share on other sites More sharing options...
August 25, 20231 yr comment_656275 On 8/24/2023 at 1:07 PM, Racer X said: Why not run the atmospheric vent from the catch cat to the exhaust downstream of the header collector, using a one way check valve, like the drag racers do? Any excess vapors are drawn into the exhaust and are burned there. Racer, I like it. Does there need to be any kind of fresh air going into the engine or is thew blow by enough? Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656275 Share on other sites More sharing options...
August 26, 20231 yr comment_656288 17 hours ago, grannyknot said: Racer, I like it. Does there need to be any kind of fresh air going into the engine or is thew blow by enough? Well what goes out needs a source. Otherwise a vacuum would be created. Just enough exchange of volume is needed to maintain a near neutral balance between atmospheric pressure and crankcase pressure. There is always some combustion pressure that leaks past the pistons. If the crankcase pressure is too high or low, the movement of the pistons will be affected. Pan evacuation is one means to keep the parasitic losses to a minimum. Link to comment https://www.classiczcars.com/forums/topic/65647-how-do-you-properly-run-an-oil-catch-can/?&page=5#findComment-656288 Share on other sites More sharing options...
