ya.. thats my next option.. i have the motor out and disassembled..  not sure if the plastic gear in there is stripped... all looks ok.. now i need to put it back together... how do i get the 3 spring loaded magnets back in there....???? can i take the gear side of the motor apart???
I have it apart.  Which bearing are you referring to? Motor seems to spin ok.  I have not opened gear side yet.  White gear looks a bit worn. But my issues was clicking when I tried to turn it on.  So power was there.
I had the same problem with the motor not running.  I bypassed the relay and connected a battery straight to the motor, and it ran.  Power goes through the relay before the motor, so I cleaned the contacts on the relay, and it worked fine.  You might give that a try.
