Posted July 29, 20213 yr comment_625939 A part that is almost always long gone on our 240z's, I am hoping to find a nearly identical to factory replacement "rubber bellows" for the choke cables for the car I am restoring. Somewhere in my thousands of hours of web-surfing, I found this picture of some of the originals: Does anyone have any originals that they could pull some measurements off of? I am looking for dimensional details of both the boots and the collars/clamps that secure the boot to the cable and sheath. I would like to fabricate the collars... but I need more info. Here are some boots I am hoping are close enough: Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/ Share on other sites More sharing options...
July 30, 20213 yr comment_625943 Where did you find those? Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625943 Share on other sites More sharing options...
July 30, 20213 yr Author comment_625944 2 minutes ago, Patcon said: Where did you find those? I came across them after doing searches for rubber bellows. It seems remote control boats use them. Search "rubber bellows boat model" on ebay. I had to buy a pack of 10, but they are cheap. Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625944 Share on other sites More sharing options...
July 30, 20213 yr comment_625945 They look pretty close. Im not sure I would worry about getting closer than that Edit: you might could scale the picture of the originals until the cable jacket is correct. Then take dimensions from the picture. We would do this all the time in Architecture Edited July 30, 20213 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625945 Share on other sites More sharing options...
July 30, 20213 yr comment_625948 I think one of my spare sets still has bellows. I'll look. Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625948 Share on other sites More sharing options...
July 30, 20213 yr comment_625951 The sum total of my choke cable boot collection. Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625951 Share on other sites More sharing options...
July 30, 20213 yr Author comment_625953 17 minutes ago, zKars said: The sum total of my choke cable boot collection. Nice - thanks for grabbing those and a pic. So, are you able to provide any details about the collars? Looking at the pic, it seems there were differences in how tall the collars/bands were. How thick is the metal they are made from? Is there just one dimple on the circumference, or more than one? Are they 6 sided? They don't look round... which I find odd. For the bellows, can you measure the rough overall length? How wide are they at the fat part of the bellow, and at the thin part? I have cables and can measure the outer diameter (OD) of the cable housing. I just haven't done so yet. Edited July 30, 20213 yr by inline6 Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625953 Share on other sites More sharing options...
July 30, 20213 yr comment_625957 I’ll give details in the morning. The collars are all hexagonal, some variety in them for sure. Bet they were round then crimped with a hex shaped crimper, kinda like a TV coax crimper. Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625957 Share on other sites More sharing options...
July 30, 20213 yr comment_625962 Does your car have the new style choke cable assembly (1972) or the early 70/71 style? Looking at the BaT sale for your car, it looks like the early type. The early type did not have the rubber bellows. I know this because I accidentally bought a 1972 style choke cable assembly and had to remove the bellows to use it in my 1970. Even then it was a problem because the new style cables are shorter. If your car has three screw carbs they might work as I believe the linkage was different than the four screw carbs on mine. I ended up selling it and repairing my broken early cable. Here is a discussion from when I sold it on here, Here are a couple more pics I took before I sold it. For reference, here is an image from the parts book. You can see the bellows on the "new type" and none on the early one. Edited July 30, 20213 yr by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625962 Share on other sites More sharing options...
July 30, 20213 yr Author comment_625993 9 hours ago, CanTechZ said: Does your car have the new style choke cable assembly (1972) or the early 70/71 style? Looking at the BaT sale for your car, it looks like the early type. The early type did not have the rubber bellows. I know this because I accidentally bought a 1972 style choke cable assembly and had to remove the bellows to use it in my 1970. Even then it was a problem because the new style cables are shorter. If your car has three screw carbs they might work as I believe the linkage was different than the four screw carbs on mine. For reference, here is an image from the parts book. You can see the bellows on the "new type" and none on the early one. Interesting. I may not need these after all. I am looking at the fitment information. How can I tell when the later type was utilized? Assembly is #20 in the image: Edited July 30, 20213 yr by inline6 Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625993 Share on other sites More sharing options...
July 30, 20213 yr comment_625995 I believe, It was started 09/71, the one I had was a 18410-E8803, but I think 18410-E8800 was actually the first version on the "new design" and it started 09/71. Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625995 Share on other sites More sharing options...
July 30, 20213 yr comment_625996 Here is what my early choke cable assembly looks like. There is not enough room for the bellows after accounting for full travel of the choke. Link to comment https://www.classiczcars.com/forums/topic/65658-size-specsdimensions-for-240z-original-choke-cable-rubber-bellows/#findComment-625996 Share on other sites More sharing options...
