Posted July 30, 20213 yr comment_625959 So my girlfriend owns a 810 and since its essentially a L24 from a 240z I assume this temperature gauge sensor works (picture below). Although it says 1970-1983 in the description so still skeptical. Does anyone know if this sensor will work? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/ Share on other sites More sharing options...
July 30, 20213 yr comment_625970 You could post photos or look at what RockAuto has. It's probably the same sender. Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/#findComment-625970 Share on other sites More sharing options...
July 30, 20213 yr Author comment_625997 You could post photos or look at what RockAuto has. It's probably the same sender.I’ll see the car Saturday, and add an update since she lives 40mins away to see if its the same sender.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/#findComment-625997 Share on other sites More sharing options...
July 31, 20213 yr comment_626033 Rock Auto shows 1981 to be the last year for the 810. Temperature sender from Beck Arnley shows they are the same for the Z series. Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/#findComment-626033 Share on other sites More sharing options...
July 31, 20213 yr Author comment_626034 Rock Auto shows 1981 to be the last year for the 810. Temperature sender from Beck Arnley shows they are the same for the Z series.I believe it is the same sender from the Z series as the engine essentially came from a 240z and was a main point of advertisement “Nissan Maxima now with the 240z engine” I believe the sender shouldwork.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/#findComment-626034 Share on other sites More sharing options...
July 31, 20213 yr comment_626035 The part number is the same for both. Might want to look into getting the threaded sleeve as well. Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/#findComment-626035 Share on other sites More sharing options...
July 31, 20213 yr Author comment_626036 The part number is the same for both. Might want to look into getting the threaded sleeve as well.Was planning on purchasing both, thank you for the information.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65659-datsun-810-1984-not-a-z-but-need-help-with-temperature-gauge/#findComment-626036 Share on other sites More sharing options...
