No power at switch.   I did always have power at switch.  Are you talking here.  ?? I always had power on red blue. But no power there now.
Fuse is ok.  Apparently other wires on plug are grounds. So I need to hook + up to those holes with test light to see what’s going on. I thought all those wires would be hot.
Not sure which side of the harness you're looking at.  Remember that the switch harness colors probably don't match the main harness colors.  Here's a better diagram.
 id like to just do the honda motor swap but i am having a hard time finding instructions on a 6 wire swap.. all 240s are 5 wires and i have a 6 wire 260 plug.. any ideas.. and do i have to disconect the relay for intermitent?
does the wiper switch ground the wiper motor? so when i test it i should hook  my test light up to the + on the battery and see if certain grounds will complete the cicuit in the wiper plug???  previously i was thinking i would see power on the wiper plug --
Google a you tube video on using a multimeter. Your looking for how to perform a continuity test and dc voltage testing. That will give you help on doing tests. If you have questions after that post them here and we can help you with testing.
