Posted July 31, 20213 yr comment_626057 When I removed the old fuel filler neck I noticed some sort of seal on the underside where it screws to the body. I'm guessing that this is to help prevent exhaust fumes from entering the cabin. What should be used to help seal this when installing the new fuel filler neck? See pictures for location I'm talking about. Link to comment https://www.classiczcars.com/forums/topic/65663-fuel-filler-neck-install-question/ Share on other sites More sharing options...
July 31, 20213 yr comment_626089 I think I just used whatever sealant I had on the shelf at the time, it doesn't need strength, the screws are taking the weight so you just need to fill the air gaps. Nice clean undercarriage! Link to comment https://www.classiczcars.com/forums/topic/65663-fuel-filler-neck-install-question/#findComment-626089 Share on other sites More sharing options...
July 31, 20213 yr Author comment_626096 1 hour ago, grannyknot said: Nice clean undercarriage! Not my car unfortunately, pix were grabbed from the internet as examples. Link to comment https://www.classiczcars.com/forums/topic/65663-fuel-filler-neck-install-question/#findComment-626096 Share on other sites More sharing options...
