Recently Browsing 0
About a year ago I experienced hesitation when I had the car on the highway at about 70 mph. I got back home and asked for advice on where to look in the system. I got a response to remove the fuel filter and blow it out with compressed air. I did that and that seemed to be the end of the problem.
Now, a couple of weeks back I had the same thing happen, so I got the car back home and took off the fuel filter and did the same thing as before. I got a lot of particulate come out as I emptied the filter and then applied compressed air. I then took the car out the next week and it was worse than before. I took the filter off and got at least as much junk as before.
My questions are as follows:
Where is a good website/place to go find new metal fuel lines? How many fuel lines are there (pick up and return)?
I supposedly had someone redo my tank and recoat it so that it was good to go. Are there any fuels that are harder on the coating than other fuels or additives?
Should I suspect anything else like the fuel pump? It appears to be doing what it has always been doing. I didn't really want to pull the fuel lines off until I found some place to replace these hoses if I needed to do that.
Any suggestions and pointers are appreciated.
https://www.classiczcars.com/forums/topic/65684-advice-on-replacing-fuel-lines-to-a-75-280-z/Share on other sites
