August 18, 20213 yr comment_627177 On 8/18/2021 at 8:40 PM, Jeff G 78 said: I don't think I've tightened any wheel in the past 30 years without using a torque wrench. How about the recommended re-torque after 100 miles? Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627177 Share on other sites More sharing options...
August 18, 20213 yr comment_627182 On 8/18/2021 at 7:38 PM, Mark Maras said: I can't be the only one here who has never used a torque wrench on lug nuts. When I was young and didn’t know any better, well, yeah, I used a lug spanner (one of those x shaped things that has three different lug nut sockets and a screwdriver looking thing on the fourth bar to remove hubcaps). Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627182 Share on other sites More sharing options...
August 18, 20213 yr comment_627183 On 8/18/2021 at 8:07 PM, Zed Head said: I never did but probably should have. I think that I used to over-torque my aluminum wheels and was distorting the rims at the seat, squishing it there. The lug nuts used to get stuck in the holes and I'd use a rat tail file to open them up a little. Probably Not Good. The aluminum slotted mags I have for my race car used shoulder lug nuts with a flat washer, and this happens to them. I use a tapered reamer to clean the holes up when they get too tight around the lug nuts. Probably lost about 1/16” of thickness over the last 30 years. Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627183 Share on other sites More sharing options...
August 18, 20213 yr Popular Post comment_627184 I'll share a story about my Dad, RIP. He never used a torque wrench or impact, just a 24" x 1/2" breaker bar and his brute gorilla arms. My younger sister and my step monster had flats over the years but could not break Pop's strength loose. Had to call roadside assistance everytime. He taught them how to put on the spare but couldn't make them as strong as he was. Me on the other hand was a touch smarter than those girls and used the scissor jack and the opposite weight of the car to break them loose. Needless to say I was his #1 son. To add context, my Dad worked for 40 years at the local Goodyear plant. He rotated all of our tires once a month just for the fun of it. Edited August 18, 20213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627184 Share on other sites More sharing options...
August 19, 20213 yr comment_627246 On 8/18/2021 at 8:40 PM, Jeff G 78 said: I don't think I've tightened any wheel in the past 30 years without using a torque wrench. I use an Milwaukee impact for removal, it makes disassembly of the car way faster. But the rule for me is that when I assemble it back up, it has to be done by hand, and torqued to spec. No bolt allowed on the car without torquing it down, I've had too many instances of "oh $^!# was it torqued?" I also don't use the electric impact to install wheels back on, I told my buddy this at the track when he wanted to borrow my tool. "Dont torque it down with the impact, I don't trust it" So he torques it down with the impact, then has to come back into the pits after a few laps because he felt the wheel was loose. Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627246 Share on other sites More sharing options...
August 20, 20213 yr comment_627260 On 8/19/2021 at 11:04 PM, heyitsrama said: I use an Milwaukee impact for removal, it makes disassembly of the car way faster. But the rule for me is that when I assemble it back up, it has to be done by hand, and torqued to spec. No bolt allowed on the car without torquing it down, I've had too many instances of "oh $^!# was it torqued?" I also don't use the electric impact to install wheels back on, I told my buddy this at the track when he wanted to borrow my tool. "Dont torque it down with the impact, I don't trust it" So he torques it down with the impact, then has to come back into the pits after a few laps because he felt the wheel was loose. Same. I will use the air or Milwaukee impact to remove nuts and to run them on only until they touch. I finish with the torque wrench. Using a paint pen on all chassis fasteners once torqued is best practice so you know they are torqued and you can easily see if they have backed off with use. Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627260 Share on other sites More sharing options...
August 20, 20213 yr comment_627263 impact is quick but it destroys the threads eventually. Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627263 Share on other sites More sharing options...
August 20, 20213 yr Popular Post comment_627264 This also works to get the nut off Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627264 Share on other sites More sharing options...
August 25, 20213 yr comment_627549 @Shawninvancouver Did you ever receive the lugnut key you ordered? Did it fit? Inquiring minds want to know. Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627549 Share on other sites More sharing options...
August 25, 20213 yr Author comment_627576 FYI. I sent some money down to Cali. Via PayPal. The guy has not set it yet as he works from 7am to 5pm 6 days a week. Will he send it?? I hope so. He says it may take him a while before he can send it. It would take me like 5 mins to walk to post office and send. Will I ever get it ?? I hope so !! Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627576 Share on other sites More sharing options...
August 26, 20213 yr comment_627589 On 8/25/2021 at 10:26 PM, Shawninvancouver said: The guy has not set it yet as he works from 7am to 5pm 6 days a week. Sixty hour work week covering the hours the Post Office is typically open and one day off? If his day off is Sunday, it may be a while before you get the lug key. Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627589 Share on other sites More sharing options...
August 29, 20213 yr comment_627737 Link to comment https://www.classiczcars.com/forums/topic/65709-what-spline-lug-lock-is-this/?&page=7#findComment-627737 Share on other sites More sharing options...
