Tachometer and wiring
Dcreech0
4 hours ago, Dcreech0 said:
Please watch and give some insight.
IMG_7379.MOV
You missed a key detail in my video. I said ALL the wires were disconnected. You had the ignition wire connected to the ballast resistor along with the green/white wire. That's why you had voltage on the black/white at coil positive.
Anyway, all the wires are connected properly. Post a photo of the back of the tach if it's still out. Let's make sure it's a 240Z tach. It would take some rewiring to mate a later tach to a 240Z, but with the other surprises on your car, we don't know what we're going to find.
The tach is the correct tach. I have read as much as I could on them and learned It is the four wire tach with the loop that reads current for the rpm.
On 8/13/2021 at 6:19 AM, Dcreech0 said:
getting my tachometer to work
So, what, in detail, does the tach do and not do?  Does the needle twitch at all when you turn the key on or start the engine?  These old tachometers fail often and in many different ways.
It does absolutely nothing. Totally dead
You might take those measurements again, following SteveJ's instruction.  Make sure that the current is actually passing through the loop.  You could also take a measurement at the tach plug to make sure the voltage is getting to the tach.  Then you'll know for sure.
1 minute ago, Dcreech0 said:
When doing the continuity tests at the coil and ballast, yes the tach was plugged in.
If you saw continuity, then never mind.
  • Who's Online   1 Member, 0 Anonymous, 779 Guests (See full list)
