August 19, 20213 yr Author comment_627226 Sorry. One more video. Will be my last. Showing what I was finding at the connection behind the tach. IMG_7385.MOV Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627226 Share on other sites More sharing options...
August 19, 20213 yr comment_627229 4 hours ago, Dcreech0 said: Please watch and give some insight. IMG_7379.MOV You missed a key detail in my video. I said ALL the wires were disconnected. You had the ignition wire connected to the ballast resistor along with the green/white wire. That's why you had voltage on the black/white at coil positive. Anyway, all the wires are connected properly. Post a photo of the back of the tach if it's still out. Let's make sure it's a 240Z tach. It would take some rewiring to mate a later tach to a 240Z, but with the other surprises on your car, we don't know what we're going to find. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627229 Share on other sites More sharing options...
August 19, 20213 yr Author comment_627230 9 minutes ago, SteveJ said: You missed a key detail in my video. I said ALL the wires were disconnected. You had the ignition wire connected to the ballast resistor along with the green/white wire. That's why you had voltage on the black/white at coil positive. Anyway, all the wires are connected properly. Post a photo of the back of the tach if it's still out. Let's make sure it's a 240Z tach. It would take some rewiring to mate a later tach to a 240Z, but with the other surprises on your car, we don't know what we're going to find. The tach is the correct tach. I have read as much as I could on them and learned It is the four wire tach with the loop that reads current for the rpm. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627230 Share on other sites More sharing options...
August 19, 20213 yr comment_627232 On 8/13/2021 at 6:19 AM, Dcreech0 said: getting my tachometer to work So, what, in detail, does the tach do and not do? Does the needle twitch at all when you turn the key on or start the engine? These old tachometers fail often and in many different ways. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627232 Share on other sites More sharing options...
August 19, 20213 yr Author comment_627233 2 minutes ago, Zed Head said: So, what, in detail, does the tach do and not do? Does the needle twitch at all when you turn the key on or start the engine? These old tachometers fail often and in many different ways. It does absolutely nothing. Totally dead Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627233 Share on other sites More sharing options...
August 19, 20213 yr comment_627234 When you did the continuity measurement, was the tach plugged in? Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627234 Share on other sites More sharing options...
August 19, 20213 yr comment_627235 2 hours ago, Dcreech0 said: Sorry. One more video. Will be my last. Showing what I was finding at the connection behind the tach. IMG_7385.MOV You should put your videos on youtube. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627235 Share on other sites More sharing options...
August 19, 20213 yr Author comment_627236 2 minutes ago, Zed Head said: You should put your videos on youtube. I will do that now with all three and post the links for you all Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627236 Share on other sites More sharing options...
August 19, 20213 yr Author comment_627237 6 minutes ago, SteveJ said: When you did the continuity measurement, was the tach plugged in? When doing the continuity tests at the coil and ballast, yes the tach was plugged in. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627237 Share on other sites More sharing options...
August 19, 20213 yr comment_627238 35 minutes ago, SteveJ said: You had the ignition wire connected to the ballast resistor along with the green/white wire. That's why you had voltage on the black/white at coil positive. You might take those measurements again, following SteveJ's instruction. Make sure that the current is actually passing through the loop. You could also take a measurement at the tach plug to make sure the voltage is getting to the tach. Then you'll know for sure. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627238 Share on other sites More sharing options...
August 19, 20213 yr comment_627239 1 minute ago, Dcreech0 said: When doing the continuity tests at the coil and ballast, yes the tach was plugged in. Just now, Zed Head said: You might take those measurements again, following SteveJ's instruction. Make sure that the current is actually passing through the loop. You could also take a measurement at the tach plug to make sure the voltage is getting to the tach. Then you'll know for sure. If you saw continuity, then never mind. Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627239 Share on other sites More sharing options...
August 19, 20213 yr Author comment_627241 41 minutes ago, Zed Head said: You should put your videos on youtube. https://youtube.com/shorts/d5huZZpAatU?feature=share https://youtube.com/shorts/qyWt6QMMlF0?feature=share https://youtube.com/shorts/s3u_VdbvO3c?feature=share Link to comment https://www.classiczcars.com/forums/topic/65710-tachometer-and-wiring/?&page=2#findComment-627241 Share on other sites More sharing options...
