Hi all,
Need a little help with replacing the stock differential mount and strap. Can this be done in my driveway by myself.
Can anyone share the process steps.
The car is stock and used mostly as a weekend cruiser.
Thanks
Yes you can do it in your driveway, you should use the search function and locate some of the old threads about this.
I personally got rid of the strap and replaced it with a RT style mount, I used the original lower diff mount and the cone style bushing.
