August 16, 20213 yr Author comment_627038 Yes. I do totally intend on adding the relay modification for sure. I just need to figure out where all the wires originally came from then go from there. I don’t see where the red/white wire would connect to under the dash. From looking at others pictures online I assume the red wire that’s missing off the combo switch goes here. But I don’t see a red/white wire under the dash to connect to. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627038 Share on other sites More sharing options...
August 16, 20213 yr comment_627040 I could give you a better clue on the wire if you could tell us what year your car is. That is why I made the previous request for you to add it to your signature. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627040 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627042 7 minutes ago, SteveJ said: I could give you a better clue on the wire if you could tell us what year your car is. That is why I made the previous request for you to add it to your signature. Gotcha, I’m sorry. I will update that now for future posts. my car is a later production date 1971. So it’s a series 2 Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627042 Share on other sites More sharing options...
August 16, 20213 yr comment_627043 Here's the problem. The wiring harness you show in your picture and the headlight switch are from a 73 or later. Post a photo of the hazard light and post the VIN on the firewall. Something is not lining up here. It could be that someone really bastardized the car. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627043 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627044 1 minute ago, SteveJ said: Here's the problem. The wiring harness you show in your picture and the headlight switch are from a 73 or later. Post a photo of the hazard light and post the VIN on the firewall. Something is not lining up here. It could be that someone really bastardized the car. Yeah. It has seen better days for sure as far as the previous owners. I know the dash has been out before and I plan on pulling it again to refurbish it. I will get those pictures posted here in about an hour when I get home from work. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627044 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627045 19 minutes ago, SteveJ said: Here's the problem. The wiring harness you show in your picture and the headlight switch are from a 73 or later. Post a photo of the hazard light and post the VIN on the firewall. Something is not lining up here. It could be that someone really bastardized the car. Another thing to mention that I have not yet and it just occurred to me with this comment. When I bought the car, the seller admitted that the dash had been swapped out for another s30 dash. Do you think the dash harness could have been swapped with this dash as well? The dash does have the pull knob type hazard switch that’s green Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627045 Share on other sites More sharing options...
August 16, 20213 yr comment_627046 2 minutes ago, Dcreech0 said: Another thing to mention that I have not yet and it just occurred to me with this comment. When I bought the car, the seller admitted that the dash had been swapped out for another s30 dash. Do you think the dash harness could have been swapped with this dash as well? The dash does have the pull knob type hazard switch that’s green So that's the 73 Hazard switch. While you're taking photos, take some in the passenger footwell where the dash harness and engine harness come together. I want to see the connectors between the two harnesses. If they have different colors, that's all from 73. I was SO hoping that someone didn't really bastardize this. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627046 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627049 10 minutes ago, SteveJ said: So that's the 73 Hazard switch. While you're taking photos, take some in the passenger footwell where the dash harness and engine harness come together. I want to see the connectors between the two harnesses. If they have different colors, that's all from 73. I was SO hoping that someone didn't really bastardize this. I know right!!! I’m willing to put in the work and fix what is needed though. It’s a good solid candidate coming from New Mexico. Body is rust free (other than floor pans). pictures coming in about 30 minutes Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627049 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627050 36 minutes ago, SteveJ said: So that's the 73 Hazard switch. While you're taking photos, take some in the passenger footwell where the dash harness and engine harness come together. I want to see the connectors between the two harnesses. If they have different colors, that's all from 73. I was SO hoping that someone didn't really bastardize this. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627050 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627053 52 minutes ago, SteveJ said: So that's the 73 Hazard switch. While you're taking photos, take some in the passenger footwell where the dash harness and engine harness come together. I want to see the connectors between the two harnesses. If they have different colors, that's all from 73. I was SO hoping that someone didn't really bastardize this. And pictures of what I have for both switches. Just for reference Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627053 Share on other sites More sharing options...
August 16, 20213 yr comment_627054 Well, the VIN looks to be from a 71, but that wiring is definitely from a 73. I wonder if the person who did this also swapped over the wiper amplifier. I suggest you download the 73 FSM for the wiring diagram. That should help you some. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627054 Share on other sites More sharing options...
August 16, 20213 yr Author comment_627055 7 minutes ago, SteveJ said: Well, the VIN looks to be from a 71, but that wiring is definitely from a 73. I wonder if the person who did this also swapped over the wiper amplifier. I suggest you download the 73 FSM for the wiring diagram. That should help you some. Okay, will do. Could you help me figure out the headlight switch though? Haha. Sorry….. I’m trying to get the car ready for a silly inspection to get it transferred to my name. Kentucky requires a sheriff to look at the car to make sure the lights, blinkers, horn etc work. Link to comment https://www.classiczcars.com/forums/topic/65716-headlight-switch/?&page=2#findComment-627055 Share on other sites More sharing options...
