Posted August 15, 20213 yr comment_626971 In the interest of guarding against potential rust, does anybody know the locations of the drains? If these are clogged, water backs up and rusts the metal out. For example, there are 3 drain holes on the bottom of both doors and one for the antenna Anybody know any others? Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/ Share on other sites More sharing options...
August 15, 20213 yr comment_626974 Cowl drain in lower front fenders, drains in rocker panels, one hole and three dimples. There are probably more. Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-626974 Share on other sites More sharing options...
August 15, 20213 yr comment_626975 Here's your cowl drain - it exits between the splash shield and A-pillar. Not visible without removing the fenders. One on each side. If a car is parked under trees, the cowl and drains can fill with leaves and trash. Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-626975 Share on other sites More sharing options...
August 15, 20213 yr comment_626987 You can remove that piece above the wiper motor and blow that drain out with air. A bunch of crap will come out. Then stick a hose pipe on it to make sure it's no backup, restrictions in there. Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-626987 Share on other sites More sharing options...
August 16, 20213 yr comment_627059 Don't forget the bottom of the fenders. Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-627059 Share on other sites More sharing options...
August 16, 20213 yr comment_627068 Those hoses actually are mounted inside the cabin under the corners of the dash. The is a screw clamp on the cowl part not shown in this pic. You can pull them off to make sure they are clear. They exit under the fender side like jfa's pic above. Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-627068 Share on other sites More sharing options...
August 19, 20213 yr comment_627194 There's another weep hole under the fenders that's filled with seam sealer from the factory - and I don't understand why. Every time we paint a Z, I dig the seam sealer out of both sides and clear out this weep hole. Here in the desert SW, very few cars actually get water up in that part of the body BUT we've had a Z come through that obviously had water in that cavity - along with other debris - that caused a great deal of rust under the fender and on top of that rail. I took some pictures of the area from another Z we have in the shop (that didn't have any rust problems under the fender😞 The first pic is right side close up. The second is the left side with the gob of sealer removed. The third is the hole backlit so you can see it. The fourth is a wider angle of the right side so you can see where I'm working. Edited August 19, 20213 yr by cgsheen1 Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-627194 Share on other sites More sharing options...
August 19, 20213 yr Author comment_627196 On 8/19/2021 at 12:08 AM, cgsheen1 said: There's another weep hole under the fenders that's filled with seam sealer from the factory - and I don't understand why. Every time we paint a Z, I dig the seam sealer out of both sides and clear out this weep hole. Here in the desert SW, very few cars actually get water up in that part of the body BUT we've had a Z come through that obviously had water in that cavity - along with other debris - that caused a great deal of rust under the fender and on top of that rail. I took some pictures of the area from another Z we have in the shop (that didn't have any rust problems under the fender😞 The first pic is right side close up. The second is the left side with the gob of sealer removed. The third is the hole backlit so you can see it. The fourth is a wider angle of the right side so you can see where I'm working. In order to get to that, I'd need to remove the fender, correct? Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-627196 Share on other sites More sharing options...
August 19, 20213 yr comment_627207 On 8/19/2021 at 1:01 AM, chaseincats said: In order to get to that, I'd need to remove the fender, correct? Yes, that is correct. Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-627207 Share on other sites More sharing options...
August 19, 20213 yr comment_627214 Just a note, be careful if you stick something into the top of the cowl trying clean debris from within rubber drain tube. Ive had one of those tube tear on me, last time I checked they were expensive. >.> Link to comment https://www.classiczcars.com/forums/topic/65720-cleaning-drains/#findComment-627214 Share on other sites More sharing options...
