Wally Posted August 21, 2021 Share #1 Posted August 21, 2021 1. can someone help tell me where the line in image 1 goes 2. In image 2, what does this line go to and whats the thing with 3 connections? much thanks Link to comment Share on other sites More sharing options...
Terrapin Z Posted August 22, 2021 Share #2 Posted August 22, 2021 The hose in pic 1 looks to be the vacuum advance for the dizzy. In pic 2 The three hose part is a valve for the fuel tank emissions. the hard line hooks to the rear pointed barb. One of the others went to a nipple on the block vent you have the blue hose on. The other barb vented to atmosphere. There are a number of threads on that part too. The blue caps on the carbs (red circle) a vents that used to go into the air box. Seeing you don't have that shown they would also vent to atmosphere. I hope that helps. Link to comment Share on other sites More sharing options...
Wally Posted August 22, 2021 Author Share #3 Posted August 22, 2021 thanks. much help. To confirm in photo here, i attached a hose to where you said correct? the bottom is left open to vent? and the top connects to the some "nipple" near the blue hose? I dont see that nipple I am wondering if this piece is even really needed/ Link to comment Share on other sites More sharing options...
Terrapin Z Posted August 22, 2021 Share #4 Posted August 22, 2021 Yes that looks right. The metal tube that came from the block have had a small tube coming out. like this pic and I think it went to the one of the barbs on the fender piece.. There is a one way valve in there so the fumes go the correct way. (If you trust the internet pic it goes on the top) I am sure there is a diagram on the forum some where. Seeing you don't have the barb on the crank case exit tube, and the part is for emissions you might just bypass it's intended function and make it look hooked up. 😀 Link to comment Share on other sites More sharing options...
jfa.series1 Posted August 22, 2021 Share #5 Posted August 22, 2021 Wally, This recent thread should cover all of your questions: 3 Link to comment Share on other sites More sharing options...
Wally Posted August 23, 2021 Author Share #6 Posted August 23, 2021 thanks all. so i removed the tube thing the barb may have been broken off or welded up. Weird. there was no barb ever there. Oh well. Link to comment Share on other sites More sharing options...
Terrapin Z Posted August 23, 2021 Share #7 Posted August 23, 2021 That kind of looks shorter than normal. Someone might have cut it shorter or made a replacement from some tubing. The later years 260-280's had a tube without the extra barb on them. maybe it was swapped out at some time. 1 Link to comment Share on other sites More sharing options...
