Posted August 29, 20213 yr comment_627706 Hey guys, I just finished restoring my 240 and trying to reinstall my seatbelts but I threw my installation guide ages ago and only have the photo below which isn't very clear. Does anyone by any chance have a clearer shot of the guide? I tried getting it off Retro Belt but they weren't responsive. Â thanks! Â Â Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/ Share on other sites More sharing options...
August 29, 20213 yr comment_627707 I'll try to take some pictures when I wash the 240Z this morning. The belts are from a different company, but the mounting looks the same. Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627707 Share on other sites More sharing options...
August 29, 20213 yr Author comment_627708 Thanks, my problem is I got a bucket full of bolts and washers and can't figure out which are for the seatbelts so was hoping to get a clearer copy of the guide since it lists the sizes of the bolts and washers. Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627708 Share on other sites More sharing options...
August 29, 20213 yr comment_627711 Well, for the hardware, post the bolt lengths you have. There shouldn't be much variation. As for bolt diameter, that should be obvious. It has to fit in the holes. Here's a close up shot of one of the anchor points. You can see how I used washers to allow it to pivot. You might see the small spacer I added to the top pivot. It keeps the pivot off of the trim. Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627711 Share on other sites More sharing options...
August 30, 20213 yr comment_627742 SteveJ: I like that belt wrapped around the seatbelt from the transmission hump. My car does not have this (yet). Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627742 Share on other sites More sharing options...
August 30, 20213 yr comment_627745 23 minutes ago, Jeff Berk said: SteveJ: I like that belt wrapped around the seatbelt from the transmission hump. My car does not have this (yet). I'm pretty sure it was a stock thing. It was in my 240Z from the time I purchased it. Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627745 Share on other sites More sharing options...
August 30, 20213 yr Author comment_627751 Oh yeah just realized I don't have the belt to hold up my seatbelt either. Trying to remember if I had it before the restoration process so I can dig it out but can't remember. I know my first 240z had it but didn't spend much time with my current z before I started the restoration 🤔. Gotta see if it's something I can get cuz would be very convenient. Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627751 Share on other sites More sharing options...
August 30, 20213 yr comment_627752 Dark green canvas, black webbing, crude sewing. Pretty basic Edited August 30, 20213 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627752 Share on other sites More sharing options...
August 30, 20213 yr comment_627785 zKars... What is the length of the loop on either side? About 8" (20 cm for everyone outside of the US)? I need to make one of those. Jeff Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627785 Share on other sites More sharing options...
August 31, 20213 yr comment_627813 I will measure it up shortly. Â Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627813 Share on other sites More sharing options...
August 31, 20213 yr comment_627830 These should give you all the measurements you need to recreate one. Sorry for the washed off numbers on my cheap cutting board work surface. The last one at the bottom edge is 15 Edited August 31, 20213 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627830 Share on other sites More sharing options...
August 31, 20213 yr Author comment_627835 thats super helpful! Link to comment https://www.classiczcars.com/forums/topic/65761-anyone-got-a-clearer-photo-of-the-retrobelt-install-guide/#findComment-627835 Share on other sites More sharing options...
