September 5, 20213 yr comment_628083 @ElMariachi Problem solved? later on i asked myself could it be that your starter is turning in the wrong direction? (+/- wrong inside or out..) just a thought.. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628083 Share on other sites More sharing options...
September 5, 20213 yr Author comment_628087 I am constrained to working on it part time on some weekends, real life gets on the way. I tried a couple different starters and they all have the exact same dimensions, including one with gear reduction. So, this is not going to be solved easily by replacing the starter. I think the long term fix is to drop the transmission and replace the ring gear and possibly the flywheel (and definitely the clutch while I'm in there). In the short term, I'm modifying one of the extra starter motors with a custom made bracket that would mount the starter and ~8mm deeper into the bell housing. This means cutting off the cast aluminum mounting tabs and attaching my bracket in the same orientation but recessed from the original. It's going to be super ugly but a chance to practice welds. I'll post pictures if I have any success. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628087 Share on other sites More sharing options...
September 5, 20213 yr comment_628097 It would be interesting to know if your ring gear/flywheel is set deeper than it should be. Need somebody with a working setup to take a measurement. Maybe a previous owner didn't know about the automatic's flex plate spacer and built their own hack to get the flywheel mounted. Good luck. Seems like a lot of work but a fun project. On 9/1/2021 at 3:19 PM, Yarb said: Recently did the a/t to manual conversion and the difference is a spacer on the crankshaft to the flex plate. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628097 Share on other sites More sharing options...
September 6, 20213 yr Author comment_628115 I finished the modification and it's a success, pictures attached. There is definitely something screwy with the flywheel/bell housing configuration. As I was installing it I pulled the spark plugs and rotated the crank shaft to listen for interference. I heard a little scraping and I painted part of the motor housing. There is about 3mm where the ring gear was grinding on the enclosure. I suspect the engine and transmission are not stock for a '76 since it has a four speed transmission and the block/head stamps match those of a '77. Regardless, I'm happy it's working again, thanks for everyone's input. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628115 Share on other sites More sharing options...
September 6, 20213 yr comment_628120 Your ring gear/flywheel/starter must have an issue. Sounds like you’ve made an adjustment on the drive gear depth but certainly not a permanent fix. Are you trying to buy time or is the fix you were looking for? Keep in mind if that ring gear comes loose for some crazy reason it will be catastrophic. Just my 2 cents. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628120 Share on other sites More sharing options...
September 6, 20213 yr comment_628122 I think that the ring gear presses down to a seat on the flywheel. Found a video. Most likely somebody hacked the flywheel on over the spacer with some longer bolts or hanging by a few threads. Like Yarb said might not be good to run it for too long. It's not right. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628122 Share on other sites More sharing options...
September 6, 20213 yr comment_628123 @Zed Headjust looked back at post #15. Could it be possible that this was an automatic at one time? Spacer never removed? Secondly the give away would be the neutral safety switch being jumpered at the harness where the reverse light harness is located. Fresh in my mind because of the conversion I’m doing. Totally different harness. Thoughts? Another thought, Would the bolts not be barely long enough to reach the crank? I realize this is a stretch…. Edited September 6, 20213 yr by Yarb Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628123 Share on other sites More sharing options...
September 6, 20213 yr Author comment_628147 Thanks for the ideas. I'll tear it apart this winter and figure out what's going on. Link to comment https://www.classiczcars.com/forums/topic/65768-starter-motor-engages-then-slips-out/?&page=2#findComment-628147 Share on other sites More sharing options...
