Getting ready to order a much needed headlight relay harness, parking light harness, and side marker conversion plugs.  I want to confirm I have the 9 pin harness plug before ordering.  I probably could build my own like others have, but looking for plug-and-play.
Where do I look for connector?  Near headlight switch on steering column?  In front of radiator?
My late 73 Z has a 7/73 built date, and does have intermittent wipers.  Probably 9 pin, just want to make sure.
Thanks, Ken
Take the cover off of the steering column. It's right at the headlight switch.
The 9 pin connector looks like this:
The 6 pin connector is much flatter and wider.
