New Member,New to Z's
SJZ
I think the factory setting for a 240 is about 5 Degrees. But it has been a LONG time since I was stock 2.4 liter.  My initial timing is about 12 degrees now with a max of 36, but I am running an MSD dizzy with an all mechanical advance due to triples.   You are blessed with a factory stock car so lets get the settings back to stock.  I think you should be at 5 degreed BDTC with no the Vac Advance plugged.  Correct me guys on this if I am misspeaking.    Lets get our friend back on track. If you are running 20 degrees on your stock car, it may be aiding your high idle.
Small world.  I live by columbia city. I used to work in Upland/GasCity.
I have a low mile factory '71, a tore down restoration project '70 and a ~'71 that had it's vin was messed with in an earlier life (but she is a little rough).  If you need to see anything, let me know. 🙂
  • Who's Online   1 Member, 0 Anonymous, 982 Guests (See full list)
