17 minutes ago, Trimpe.bob@gmail.com said:
I bought these to go on my 73 Z bumper. They don't quite clear the rubber trim in front (they are a little wide).
Are these for 1973 240Z?
They appear to be correct for a 73. The bumperette will overlap the rubber trim strip when they are installed. See the notch in the side profile of the left bumperette in your photo?
That notch will fit over the rubber trim strip close to the end and will actually compress the rubber when fully tightened down if the rubber trim strip and bumperette are positioned correctly. The trim strip holes in the bumper are elongated and give some latitude for adjustment. Crowd the elongated holes to the side towards the bumperette as you install the rubber trim from the center of the bumper towards each end.
