I think at some point my right rear turn signal was working fine. It IS NOT working now. At the 4 prong square connector that feeds the light harness at the rear of the car I have power coming from the front of the car. Check with the test light and it blinks fine when its unplugged....Plug it in a NO flashing. However the Hazard lights that seem to run on the same wire work perfectly fine. Does anyone have any suggestions as to where to look for a problem. Only think I can think of is there is a separate ground for the Hazards vs the Turn Signal. The front right turn signal works fine, this is just on the rear.
https://www.classiczcars.com/forums/topic/65790-rear-turn-signal-mystery/
