September 13, 20213 yr Author comment_628479 On 9/10/2021 at 9:17 PM, Reptoid Overlords said: On a budget? I'll bet these'll do https://www.ebay.com/itm/124681185423?hash=item1d0793e88f:g:JnAAAOSwSthgd1eM Or be the envy of your social circle https://store.jenvey.co.uk/throttle-body-kits/nissan/nissan-datsun-cknn03-1 Dayum Those Jenvey's look really nice. And way cheaper than Mikuni Any experience with them? Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-628479 Share on other sites More sharing options...
September 13, 20213 yr Author comment_628480 On 9/10/2021 at 8:46 PM, Patcon said: The factory system is very primitive. A modern efi system with closed loop fueling is miles ahead of the original system. Yes, a complete new system. Very similar to triple mikunis but triple throttle bodies instead. Look up Jenvey's I really might go that direction. It would be hard to abandon my vision for the car. Maybe ill just come back to it in the future That is one of the greatest things about these S30s. You can continue to work on them and change them Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-628480 Share on other sites More sharing options...
September 29, 20213 yr Author comment_629196 Follow Up: On the 18th of September, I began to work on EGR after receiving the EGR Delete Kit. The install of the plate was simple. Although, I believe I might have taken a bit too much off the manifold when using a Dremel to try and remove the caked on gasket. But that wont matter, because I will likely have to remove the Intake Manifold now... I soaked the nut/bolt that holds the EGR pipe to the Exhaust Manifold several times in several de-locking treatments. The head still broke off because the piece is likely rust welded into the manifold. So now I need to manage that issue. I am thinking of just going straight for headers and upgrading the exhaust system all together. Of course I am entertaining all thoughts and would love your feedback! Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629196 Share on other sites More sharing options...
September 29, 20213 yr comment_629204 Headers and an N42 intake off a '75 or '76. Pre EGR. Edited September 29, 20213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629204 Share on other sites More sharing options...
September 29, 20213 yr Author comment_629211 On 9/29/2021 at 8:20 PM, siteunseen said: Headers and an N42 intake off a '75 or '76. Pre EGR. Do you have any recommendations on headers? I believe the L28 block has square shaped ports, but most headers seem to have circle shaped ports. Do you have any insight on that? Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629211 Share on other sites More sharing options...
September 29, 20213 yr comment_629213 It'll depend on which head you have what shape the exhaust ports are. Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629213 Share on other sites More sharing options...
September 29, 20213 yr Author comment_629215 On 9/29/2021 at 10:01 PM, Reptoid Overlords said: It'll depend on which head you have what shape the exhaust ports are. Is there a way to find out without taking the exhaust manifold off to check? Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629215 Share on other sites More sharing options...
September 29, 20213 yr comment_629216 On 9/29/2021 at 10:10 PM, SupremeCling said: Is there a way to find out without taking the exhaust manifold off to check? http://xenonzcar.com/s30/heads.html Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629216 Share on other sites More sharing options...
September 29, 20213 yr comment_629219 Just in case your engine has been swapped with a later ZX motor or Frankensteined out of a later head/earlier block, look on the passenger side along the bottom of the head for the head identification..It'll likely be N47 Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629219 Share on other sites More sharing options...
September 29, 20213 yr comment_629226 On 9/29/2021 at 5:23 PM, SupremeCling said: receiving the EGR Delete Kit. There's a kit? Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629226 Share on other sites More sharing options...
September 30, 20213 yr comment_629228 On 9/29/2021 at 11:45 PM, Zed Head said: There's a kit? I sure wish there was! I read for hours before I figured mine out but it was worth it. Maybe the block off plate and gasket? But there's a lot more to it than that if you do the hole $^!# and kaboodle. Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629228 Share on other sites More sharing options...
September 30, 20213 yr Author comment_629231 On 9/29/2021 at 10:21 PM, siteunseen said: http://xenonzcar.com/s30/heads.html Turns out I have diamond ports! Any recommendations on aftermarket headers with diamond ports? Link to comment https://www.classiczcars.com/forums/topic/65806-overheating-egr-delete/?&page=2#findComment-629231 Share on other sites More sharing options...
