Posted September 13, 20213 yr comment_628492 My 1976 Z has developed a parasitic current draw which drains the battery in a couple of days. I have traced it to the front right fusible link. That's the foreward one next to the fender, and it is brown. My eyes aren't good enough to read the wiring diagrams, so hoping someone can give me a hint on what this link protects. It started around the time I replaced the alternator with a new one from Autozone. I still have the external voltage regulator. Any helpful advice is greatly appreciated. Joe Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/ Share on other sites More sharing options...
September 13, 20213 yr comment_628494 43 minutes ago, Humbug said: My 1976 Z has developed a parasitic current draw which drains the battery in a couple of days. I have traced it to the front right fusible link. That's the foreward one next to the fender, and it is brown. My eyes aren't good enough to read the wiring diagrams, so hoping someone can give me a hint on what this link protects. It started around the time I replaced the alternator with a new one from Autozone. I still have the external voltage regulator. Any helpful advice is greatly appreciated. Joe Have you measures the current draw? Unplug the voltage regulator and see if you still have a current draw. Edited September 14, 20213 yr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628494 Share on other sites More sharing options...
September 14, 20213 yr comment_628501 You said the problem started shortly after you replaced the alternator. So as Captain Obvious, it is my duty to suggest you start your investigation there. I suggest you disconnect your new alternator and see what happens. Also, as a side note,,, For a 76, that front outboard link should be black, not brown. And it should be the largest link you have. That link powers a whooooooole bunch of stuff. Hopefully the issue is in the alternator and you can end the search with that. Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628501 Share on other sites More sharing options...
September 14, 20213 yr comment_628504 3 hours ago, Humbug said: replaced the alternator with a new one from Autozone. I still have the external voltage regulator. Why did you replace the alternator? The VR has current path errors possible also. If you were getting zero charge, probably the alternator. Overcharge, probably the VR. And don't assume that Autozone gave you the correct product. Could be they gave you an internally regulated alternator. Here's a nice diagram. Note that what people are calling Red now actually started as Brown.  Had it Copied, didn't Paste it.  Edited September 14, 20213 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628504 Share on other sites More sharing options...
September 14, 20213 yr Author comment_628505 Thanks. I checked the diode in the alternator, and it passed, but I've not completely disconnected the alternator. I rechecked the wire in the link, and it is blue. I put a full charge on the red optima battery last night and fooled around with tests today. Then I left the battery disconnected. Later, when I checked, it had three volts, I am going to get a new battery in the morning and start over. Joe Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628505 Share on other sites More sharing options...
September 14, 20213 yr Author comment_628507 I replaced the alternator because it wasn't putting any charge at all to the battery. After I put the new one in, it didn't work, either. I later ravved the engine, and the alternator started working, putting about 14v to the battery. Electricity is devious, in my experience. Â Zed Head, I'm not seeing any diagram. Joe Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628507 Share on other sites More sharing options...
September 14, 20213 yr comment_628508 did you completely disconnect the alt? that is both the large cable to the positive terminal as well as the two prong plug? as aready mentioned I wonder if you are mixing a internally regulated alt with a external VR, that would not be a good idea. Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628508 Share on other sites More sharing options...
September 14, 20213 yr comment_628509 If you have a test light, use it between the negative post and the end of the battery cable before you connect it, with the positive cable connected. The only draw you should have is the clock. You could remove the fuse for the clock, whichever one it is, if you want to remove all potential draws. You can also look for sparks, and/or measure amps drawn, depending on what tools you have. 16 minutes ago, Humbug said: I later ravved the engine, and the alternator started working, putting about 14v to the battery. This is what people have to do when their Field wire is not connected. That comes through the VR. Might be that your old alternator was fine and the VR is the problem. Measure voltage at the bottom of the "T" in the plug at the back of the alternator with the key on. Edited September 14, 20213 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628509 Share on other sites More sharing options...
September 15, 20213 yr Author comment_628583 With the new battery, the alternator is making 16.4 volts, and there are some slightly melted wires in the harness at the voltage regulator, so I assume the VR is shot. I've ordered a new one, and will see where this takes me. Joe Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628583 Share on other sites More sharing options...
September 16, 20213 yr comment_628587 2 hours ago, Humbug said: With the new battery, the alternator is making 16.4 volts, and there are some slightly melted wires in the harness at the voltage regulator, so I assume the VR is shot. I've ordered a new one, and will see where this takes me. Joe Did you get a 40A alternator or did it have a higher rating? The 40A needs an external VR. Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628587 Share on other sites More sharing options...
September 16, 20213 yr comment_628593 76 had a 60A and an external VR.  There's a procedure in the FSM for checking the VR. Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628593 Share on other sites More sharing options...
September 16, 20213 yr comment_628595 6 minutes ago, Zed Head said: 76 had a 60A and an external VR.  There's a procedure in the FSM for checking the VR. D'oh! I was going from memory. I'm getting too old to do that. Link to comment https://www.classiczcars.com/forums/topic/65819-current-draw-traced-to-fusible-link/#findComment-628595 Share on other sites More sharing options...
