September 17, 20213 yr comment_628659 That white 'nut' screws in and out to adjust the outside handle actuator. If it is adjusted too tight, you cannot operate the door lock. Make sure you adjust it with the door lock engaged, as if the door were closed. Also note that the key lock and the inside lock work together. That is, when you operate the inside lock, you will see the locking rod on the key lock also moving. Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-628659 Share on other sites More sharing options...
September 17, 20213 yr comment_628673 Also that actuator bar looks bent Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-628673 Share on other sites More sharing options...
March 20, 20223 yr comment_637430 I bought the same lock set for my 1970 240z they are junk never could get them to work properly Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-637430 Share on other sites More sharing options...
August 3, 20231 yr comment_655633 On 9/17/2021 at 5:21 PM, CanTechZ said: For those with early cars who may find this discussion later, here is a close up picture of the connection from the actuator on the key cylinder to the rod on the door lock mechanism. It shows the split plastic bushing that is used, instead of a clip type connection as shown above. Anyone knows if, on the original door lock cylinders, if you disassemble them, does everything come out from the back of the cylinder, or the front? this photo is giving me hope it's from the back. Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-655633 Share on other sites More sharing options...
August 3, 20231 yr comment_655638 Sorry, but no. Everything comes out the front. You have to uncrimp the stainless cover on the side where you insert the key. That silver cover is known as a "facecap", and it's crimped in place. Here's a pic of the facecap removed and the lock partially disassembled: Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-655638 Share on other sites More sharing options...
August 3, 20231 yr comment_655644 Ugh, what I was afraid of. Thanks for the info! Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-655644 Share on other sites More sharing options...
August 4, 20231 yr comment_655655 Yup. Sorry to be the bearer of bad news. Good luck with the project! Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-655655 Share on other sites More sharing options...
August 4, 20231 yr comment_655657 On 8/3/2023 at 6:15 PM, Interceptor said: Ugh, what I was afraid of. Don't be afraid of it.. just take a very little (we call them watch) screwdriver and do this in a clean well lighted work-room/place. Take the lock and (make pictures all the time..) and simply uncrimp the stainless.. if you think you can't do it .. try it first on one you don't use.. It's more simple than you think and practice makes perfect. Keep the parts in a row and work slowly and careful.. you CAN do it! Link to comment https://www.classiczcars.com/forums/topic/65823-door-locking-mechanism-71-240z/?&page=2#findComment-655657 Share on other sites More sharing options...
