Posted June 11, 200321 yr comment_40615 Hey Guys; Iam building a 72 with a small block Chevy and a 700R4. According to the JTR book the stock shifter and linkage will hook-up to the trans, and it does. The question, in the book it shows the shifter mounted to a piece of angle iron which is bolted to the trans, is this a inorder to prevent the trans from accidently shifting from torque or could the shifter be mounted to the floor??? How about using a cable shift, from a Camaro, mounted to the stock shifter . Thanks for the input in advance!! Peter Link to comment https://www.classiczcars.com/forums/topic/6586-shifter-stuff/ Share on other sites More sharing options...
June 24, 200321 yr Author comment_41883 Hey Guys; I am surprised I havn't got any input:ermm: Is it possible, the mass are stumped?? or is this a stupid question Link to comment https://www.classiczcars.com/forums/topic/6586-shifter-stuff/#findComment-41883 Share on other sites More sharing options...
June 24, 200321 yr comment_41908 I wish i had the answer to your question but ........I think the best place to get it is at hybridz.orgmany members there have done almost any kind of engine swap and will have the info you need. Link to comment https://www.classiczcars.com/forums/topic/6586-shifter-stuff/#findComment-41908 Share on other sites More sharing options...
