It looks like both of the bolts that attaches the housing to the head are broken in the pic.
There is usually a lot of corrosion in those bolt holes in the housing and that front one is long.
Maybe PB Blaster, some tapping, heat, and later some gentle prying repeated multiple times may free it up so you can slide the housing off and then get the bolts out.
Jar it with a sand hammer on both sides and it might pry off with a little persuasion. If you look at the FSM it will illustrate how it’s mounted on the head itself. Should pull off towards the driver side fender.
Very fortunate they did not snap off at the head. Still a lot of fun ahead once the housing is removed. Back and forth with small increments may have prevented them snapping off. Had about a 50% luck ratio trying that method. As you know sometimes it just isn’t going to budge….
