Posted October 8, 20213 yr comment_629749 Does anyone know where I can get new hardlines for a 260z? I’m doing a frame up restoration and would like to get them new if possible. I.e fuel lines, brake lines. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/ Share on other sites More sharing options...
October 9, 20213 yr comment_629766 is this an early 260z or a late 260z? The early 260z might share brake lines with the late 240z. the fuel lines might be different, i can take a look at my late 73 chassis and compare to my early 74... in which case https://classictube.com/model/240z-7/ might work... Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-629766 Share on other sites More sharing options...
October 9, 20213 yr comment_629767 Also LHD v RHD makes a big difference on brake lines routing. Tell us more about the car. Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-629767 Share on other sites More sharing options...
April 19, 20223 yr Author comment_639474 Long time no post, I believe I have a late model 1974 260z. It is left hand drive. I’m going to swap a turbo L28. Should I just change everything to SS Braided lines?Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639474 Share on other sites More sharing options...
April 19, 20223 yr comment_639475 @Yarbhad problems with the stainless lines he purchased from ClassicTube. Maybe he will chime in. Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639475 Share on other sites More sharing options...
April 19, 20223 yr comment_639476 Definitely stay away from the stainless. Not sure what the issue is but just with gravity feed through the master I had leaks at the MC and the unions. Just received the OE replacement lines. I’ll report back once installed. I can tell you the OE is much more flexible than the stainless. Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639476 Share on other sites More sharing options...
April 19, 20223 yr comment_639494 try a dealer you might get lucky Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639494 Share on other sites More sharing options...
April 20, 20223 yr comment_639504 Which dealer are you suggesting? Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639504 Share on other sites More sharing options...
April 20, 20223 yr Author comment_639540 Anyone aware of the part #?Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639540 Share on other sites More sharing options...
April 20, 20223 yr comment_639550 On 4/20/2022 at 1:05 AM, Yarb said: Which dealer are you suggesting? try any dealer or nissan parts.com On 4/19/2022 at 11:09 PM, kully 560 said: try a dealer you might get lucky Link to comment https://www.classiczcars.com/forums/topic/65911-260z-hardlines/#findComment-639550 Share on other sites More sharing options...
