280z ecu's
ennisdavis
Different manufacturers making the same design.  There have been a few discussions about the differences but it seems that any ECU from 75 to through 78 will work on any EFI engine.  I tried the range, except 77, on my 76 and they all worked.  The 78 ECU did crap out on me after a short drive, but I think that's why the car was being parted out.  The one thing that won't work without the proper ECU is the altitude fuel adjustment.
Here's another ECU link.
It’s not really cryptic NMC and JECS are two different manufacturers for the same part. Some people say you can interchange them and it’s the connector to the AFM that matters. What are you trying to solve that you think you need to swap out what was in the car?
