L28 front cover
ennisdavis
13 hours ago, ennisdavis said:
I have worked on engines for over 40 years and have never seen such a bad design.
Worked on engines?  i'm sorry but you polished engines or so?:ph34r:  Well you ask a LOT of questions that are simple to answer for someone that worked for 40 years on engines? What you have there is a bolt without it's head... some guy... must have taken it right off!
21 hours ago, ennisdavis said:
Thats the point to me posting the picture. The head broke off because the bolt is thinner then a pencil. As long as one too. And thats not a bad design?
Not sure why you are trying to redesign the L motor . Take any other engine of its era and will see it’s a superior design . Properly maintained it’s probably one of the best engineered engines of its time . That bolt would have been fine if the owner had used coolant instead of water . We see it all the time . I challenge you to find a motor of that period that has forged internals for the most part and precise machined surfaces .
  • Like 4
  • 2 years later...
It seems I'll be servicing my front cover (see attached).  But, from this and other discussions, I'm glad my oil leak isn't a blown head gasket.  I get fresh, new unburned oil at the corner of the cover and block (under the masking tape). Its annoying to have had this leaking for a long time and being unable to isolate the source.  I first replaced the valve cover gasket. So, I know I'll pull the radiator, shrouds, fan and belts. Is it fairly straight forward to:
- drop the pan entirely and go with a new gasket after thorough cleaning (its totally fouled from the oil of this leak)
- pull the pump and front cover from the block (oh, and drain the oil first)....  or can the pump and cover come off as a unit?
- gaskets needed on the front cover or just sealer?
Thanks,
Ed
