Posted October 20, 20213 yr comment_630239 The radiator cap of the Champion 3 row radiator is really worn. Would this 16lbs Stant Cap work and help lowering the temperature? https://www.amazon.com/Stant-10230-Radiator-Cap/dp/B000B8LKVY/ref=sr_1_2?dchild=1&keywords=Stant+radiator+cap&qid=1634738898&qsid=135-7717209-6316309&sr=8-2&sres=B000B8LKZ0%2CB000B8LKVY%2CB000B8N3G4%2CB000C846LY%2CB00180JSSQ%2CB000B8LKYQ%2CB000E3ZLM0%2CB00180JSP4%2CB000C8227E%2CB000B8JUGQ%2CB000C808SE%2CB000B8JUG6%2CB000B8N3GE%2CB000B8N3J6%2CB000C808T8%2CB000C8224M&srpt=ENGINE_COMPONENT_CAP The one that my radiator currently carries is labeled 1.1 Link to comment https://www.classiczcars.com/forums/topic/65945-16lbs-stant-radiator-cap-for-champion-3-row-radiator/ Share on other sites More sharing options...
October 20, 20213 yr comment_630252 What does worn mean? Pictures?? It will not change the temperature in the radiator at all! It will boil at a higher temperature but then you might bust hoses at the higher pressure or have leaks. "If it's not broke; don't break it!!" Link to comment https://www.classiczcars.com/forums/topic/65945-16lbs-stant-radiator-cap-for-champion-3-row-radiator/#findComment-630252 Share on other sites More sharing options...
October 21, 20213 yr comment_630261 On 10/20/2021 at 2:14 PM, jalexquijano said: help lowering the temperature? You use a Aluminium radiator? Let me just say this: There is no better radiator than a copper one!!! Personally i HATE those stupid aluminum (or aluminium) radiator makers.. they say their 3 row is a very good radiator... NO a 3 row COPPER radiator is MUCH better.. I don't no i have not tested it but i Bet that even a 2 row copper radiator cools better than a 3 row alu.. Yes a copper one is much more expensive, thats why the alu is popular.. not that it's better... All Z's & ZX's have copper radiators for a reason.. 👍 Link to comment https://www.classiczcars.com/forums/topic/65945-16lbs-stant-radiator-cap-for-champion-3-row-radiator/#findComment-630261 Share on other sites More sharing options...
October 21, 20213 yr comment_630262 On 10/20/2021 at 2:14 PM, jalexquijano said: one that my radiator currently carries is labeled 1.1 Yeah that means it opens at 1,1 Bar. (15,95 Lbs per square inch) i would'nt go much higher.. (i know that my 300zxtt works at 1,2 Bar (17,4 Lbs/sq Inch.) Link to comment https://www.classiczcars.com/forums/topic/65945-16lbs-stant-radiator-cap-for-champion-3-row-radiator/#findComment-630262 Share on other sites More sharing options...
November 2, 20213 yr Author comment_630873 Bought the wrong cap. Damn!! The one my radiator carries is the one in the pic Link to comment https://www.classiczcars.com/forums/topic/65945-16lbs-stant-radiator-cap-for-champion-3-row-radiator/#findComment-630873 Share on other sites More sharing options...
