November 2, 20213 yr Author comment_630842 Is there anything that shows an expanded view of it dissembled that I can try to follow. Is it in the FSM Link to comment https://www.classiczcars.com/forums/topic/65960-headlights-not-working/?&page=2#findComment-630842 Share on other sites More sharing options...
November 2, 20213 yr comment_630849 Here's a pretty recent thread. He doesn't show the actual prying up of the metal tabs but you can probably figure it out. A small screwdriver, some needle nose, whatever your favorite tools are. Open it over a box top or a surface where you can find the little parts when they get away. Pic 36 is the start, about 2/3 down the page. Link to comment https://www.classiczcars.com/forums/topic/65960-headlights-not-working/?&page=2#findComment-630849 Share on other sites More sharing options...
November 2, 20213 yr comment_630855 5 hours ago, Zed Head said: Open it over a box top or a surface where you can find the little parts when they get away. Yeah.. and under a umbrella when things start to fly..! NO.. just kidding.. i don't think things immediately jump out.. read the tread about it first careflly and you know what to do.. When i go restore my 240z i will bring relais into the headlight circuit because those switches are first very expensive and the contacts are not up to the job (full amps from the 2 lamps is to much.. ) Better to use a relais for the front headlights.. unless there is something available in LED. ( by that time...) I rarely drive for a hour in the dark but after a half an hour i can smell the contacts hahaha... Link to comment https://www.classiczcars.com/forums/topic/65960-headlights-not-working/?&page=2#findComment-630855 Share on other sites More sharing options...
November 8, 20213 yr comment_631175 On 11/2/2021 at 3:31 AM, dutchzcarguy said: Better to use a relais for the front headlights.. unless there is something available in LED. ( by that time...) I would do the headlight relays even if you go LED headlights. I used these LED headlamps and if you don't do the relays you'll have to use the anti-flicker module which is a pain to get them in the bucket with the headlamp. My first post in this thread shows the stock wiring and how it's changed with the headlight relays. The relays make it so the ground and power leads flow the electrons in the proper direction for the LED bulbs. Link to comment https://www.classiczcars.com/forums/topic/65960-headlights-not-working/?&page=2#findComment-631175 Share on other sites More sharing options...
