Oil pump
ennisdavis
On 10/25/2021 at 7:08 AM, ensys said:
With that in mind, it would seem worth the effort to pull the distributor and fill the open bore with your favorite thin rust-buster and leave it overnite to steep. Bonus Luck points if the liquid makes it thru to the drive rotor.
$.02 from the cheap seats.
That'll just dilute the engine oil with rustbuster, won't go anywhere near the oil pump!
The pump drive shaft bore is not connected to the circulation pathways. Those ports are in the case. If you remove the base plate, the sump will not drain; the oil must first be drawn up by the action of the pump.
Based on what the rest of your car looks like I would whack the crap out of it until it falls off.  Most likely the pump has never been removed and was submerged under the ocean or wherever your car was sitting to get so rusty. No offense about your car I just mean it’s literally probably just sealed on there from the years and years of neglect and outside environmental forces
Edited by AZDatsun
  • Who's Online   1 Member, 1 Anonymous, 508 Guests (See full list)
