October 26, 20213 yr comment_630497 On 10/25/2021 at 6:08 AM, ensys said: With that in mind, it would seem worth the effort to pull the distributor and fill the open bore with your favorite thin rust-buster and leave it overnite to steep. Bonus Luck points if the liquid makes it thru to the drive rotor. $.02 from the cheap seats. That'll just dilute the engine oil with rustbuster, won't go anywhere near the oil pump! Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630497 Share on other sites More sharing options...
October 27, 20213 yr comment_630536 The pump drive shaft bore is not connected to the circulation pathways. Those ports are in the case. If you remove the base plate, the sump will not drain; the oil must first be drawn up by the action of the pump. Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630536 Share on other sites More sharing options...
October 27, 20213 yr Author comment_630547 What drives the oil pump and distributor Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630547 Share on other sites More sharing options...
October 27, 20213 yr comment_630548 On 10/27/2021 at 3:34 PM, ennisdavis said: What drives the oil pump and distributor their shared spindle which is driven by a gear on the crank shaft. Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630548 Share on other sites More sharing options...
October 27, 20213 yr comment_630550 Hammer time. Supposed to start at 11:00 minutes. Edited October 27, 20213 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630550 Share on other sites More sharing options...
October 27, 20213 yr comment_630553 Based on what the rest of your car looks like I would whack the crap out of it until it falls off. Most likely the pump has never been removed and was submerged under the ocean or wherever your car was sitting to get so rusty. No offense about your car I just mean it’s literally probably just sealed on there from the years and years of neglect and outside environmental forces Edited October 27, 20213 yr by AZDatsun Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630553 Share on other sites More sharing options...
October 28, 20213 yr Author comment_630578 A 45 year old jap car without rust? All z's i have seen are rusty. Only only i have seen that was rust free sold for over $100k Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630578 Share on other sites More sharing options...
October 28, 20213 yr comment_630579 It depends a lot on where you live. My current project was very rust free. And only required two small floor board patches. They are getting more rare though Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630579 Share on other sites More sharing options...
October 28, 20213 yr Author comment_630588 I dont see that gear and shaft for the dist driver on the exploded views of the engine. Pics would be appreciated Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630588 Share on other sites More sharing options...
October 28, 20213 yr comment_630593 The video shows the shaft and pump assembly. Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630593 Share on other sites More sharing options...
October 28, 20213 yr comment_630594 this is the gear on the crank that that spindle engages with, as it goes diagonally across the top of it at about 10 o clock. Edited October 28, 20213 yr by jonbill Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630594 Share on other sites More sharing options...
October 28, 20213 yr Author comment_630595 It that a water freeze plug? Hope not Link to comment https://www.classiczcars.com/forums/topic/65962-oil-pump/?&page=2#findComment-630595 Share on other sites More sharing options...
