El-pelukas Posted October 25, 2021 Share #1 Posted October 25, 2021 Hey people, I'm new to this page. I just bought a 280z and I ive been working on it. I had it running for the past 3 days. I noticed it had a Air leak after the air flow meter so I drove to the parts store got some hose, then drove back installed it. now the car won't even start. I need help! I have tried everything I can to get it to run, it wont even start on starting fluid. Have spark in all the plugs. Link to comment Share on other sites More sharing options...
Dave WM Posted October 25, 2021 Share #2 Posted October 25, 2021 not sure what is going on with the gas station filling up. I presume its some kind of fuel cell? If that is the case are there any other modifications? if there are help will be limited to statements like "have you got spark" etc... Typically you should start by reading the factory service manuals. These cars have a very simple fuel injection system, as well as ignition system (by modern car standards). what they don't have is OBD so you have to follow a procedure using test equipment like a volt ohm meter (aka digital multimeter) even a test light will check a lot of stuff. Saying you tried everything is not much help, exactly what did you try? Lets start with the basics it worked somewhat until you did something, can you undo what you did and try again? assuming it never worked, you should start with a compression test, then check the timing (spark and valve), are the spark plugs actually firing in the correct order, are you getting fuel to the injectors, is the fuel pressure correct, are the injectors clicking are the passing fuel when clicking... again you should read the FSM until you know it very well, then follow the checks, this is the best way to resolve the issues. The only thing not really covered is age related problems so make sure the ground connections are good and the wire harness is free of corrosion, those can give readings that are hard to figure out when doing the checks. Link to comment Share on other sites More sharing options...
Patcon Posted October 25, 2021 Share #3 Posted October 25, 2021 How are you adding the starter fluid? Link to comment Share on other sites More sharing options...
Zed Head Posted October 25, 2021 Share #4 Posted October 25, 2021 10 hours ago, El-pelukas said: I had it running for the past 3 days. I noticed it had a Air leak after the air flow meter so I drove to the parts store got some hose, then drove back installed it. now the car won't even start. If it ran before it seems like nothing major would have happened just from disconnecting and reconnecting the AFM hose. I don't know that I would start messing with things that you haven't touched. Focus on the area you were working in. Looks like you disconnected the throttle valve sensor for some reason. What else did you disconnect? One strong possibility is that you disconnected the water temperature sensor and are flooding it. That would be one reason starting fluid doesn't work. I agree with Dave, that internal fuel tank looks scary. Reminds me of what I saw in a wrecking yard once. A full size fuel tank strapped inside the car, a Z, with hoses running through holes up to the engine. A firebomb waiting to happen. Link to comment Share on other sites More sharing options...
siteunseen Posted October 25, 2021 Share #5 Posted October 25, 2021 You need that accordion hose from the AFM to the throttle plate. Is that where you're squirting start fluid? Also the TPS needs to be plugged in like Zed Head mentioned. Both are in this picture. Link to comment Share on other sites More sharing options...
siteunseen Posted October 25, 2021 Share #6 Posted October 25, 2021 (edited) I've seen flexible aluminum hose used before. Can't remember if it was cloths dryer exhaust hose or water heater vent pipe, sorry. If the original rubber one isn't too bad you could seal it with silicone. We used Shoe Goo back in the 80s bought at sporting goods stores for fixing tennis shoes. Walmart has it online, not sure about in store. Edited October 25, 2021 by siteunseen Link to comment Share on other sites More sharing options...
Zed Head Posted October 25, 2021 Share #7 Posted October 25, 2021 15 hours ago, El-pelukas said: noticed it had a Air leak after the air flow meter so I drove to the parts store got some hose, then drove back installed it. I think that he probably got some of that blue silicone hose at OReilly or Autozone. 1 Link to comment Share on other sites More sharing options...
chaseincats Posted November 2, 2021 Share #8 Posted November 2, 2021 why is there no afm to tb hose... Link to comment Share on other sites More sharing options...
Zed Head Posted November 2, 2021 Share #9 Posted November 2, 2021 3 minutes ago, chaseincats said: why is there no afm to tb hose... On 10/25/2021 at 12:39 AM, El-pelukas said: I noticed it had a Air leak after the air flow meter so I drove to the parts store got some hose, then drove back installed it. Link to comment Share on other sites More sharing options...
chaseincats Posted November 2, 2021 Share #10 Posted November 2, 2021 well put it on already 1 Link to comment Share on other sites More sharing options...
siteunseen Posted November 2, 2021 Share #11 Posted November 2, 2021 On 10/25/2021 at 6:37 PM, Zed Head said: I think that he probably got some of that blue silicone hose at OReilly or Autozone. That's the hose people do "cold air intakes"? I've seen that before. Link to comment Share on other sites More sharing options...
