Recently Browsing 0
need some advice. Apparently i have all the ignition stuff on and was trying to fire up the car. It turns over great it just wont ignite and crank.
No idea what the issue is or even could be. Everything is rebuilt and new including new Ztherapy carbs, lines etc. Gas is being pushed from the mechanic fuel pump and all the plugs are sparking good.
Could some wires not 100% right at the ignition or ballast cause this? What about bad timing? Any thoughts are welcome
https://www.classiczcars.com/forums/topic/65981-car-will-not-start/Share on other sites
