November 11, 20213 yr comment_631382 Lash pads are not the same as setting the valve lash. I can't speak to the technique to measure for the proper size lash pad, but maybe someone who does will chime in. This is the wrench set I like to use for adjusting the valve lash. They are not as thick as your typical wrenches, so it makes it easier to put both wrenches on the nuts for the valve adjustment. https://www.tme.com/us/en-us/details/wp-w003300we/wrenches-sets/workpro/w003300/ Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631382 Share on other sites More sharing options...
November 11, 20213 yr comment_631383 Here is a good tutorial on how to do the valve adjustment: https://web.archive.org/web/20080720024048/http://www.picturetrail.com/gallery/view?p=12&uid=786489&gid=1803105 Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631383 Share on other sites More sharing options...
November 11, 20213 yr Author comment_631389 I just did a compression test for each cylinder. Here are results 1: 150 2: 149-150 3. 165 4. 140-141 or so 5. 155 6. 160 i read here on forum somewhere 175-180ish is normal? Does this indicate a lash or camshaft problem? Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631389 Share on other sites More sharing options...
November 11, 20213 yr comment_631390 Considering the engine was worked on, the readings seem low and all over the place. However, there can be variability in compression gauges. Also, technique is important. Make sure you look at what the ET section of the FSM says. Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631390 Share on other sites More sharing options...
November 11, 20213 yr Author comment_631392 i think pattern is right but #s are in order and actual. pretty bad? i Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631392 Share on other sites More sharing options...
November 11, 20213 yr comment_631393 Wow, how about shooting some video of you taking measurements just to make sure you're doing it right. Those measurements are way off. Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631393 Share on other sites More sharing options...
November 11, 20213 yr comment_631394 The compression number range is not terrible. 12.5% on #4, the worst one (actually 15% - 25/165). The equipment used will affect the readings. And the lash readings do show lash so the valves should be closing. Maybe the engine spins fast because you have a powerful battery. You have reasonable cylinder pressures and the engine is spinning. The engine should start. So, spark is left as the unknown. With the engine spinning that fast you should be able to get a nice stable ignition timing reading with a timing light. If you can do that, it will tell a lot. And, there are no pictures of your spark plug wiring. Might be that they are incorrect. 1 5 3 6 2 4 counterclockwise. Spark and ignition timing seem like the main unknowns at this point. They have not been confirmed. On 11/11/2021 at 3:02 PM, Wally said: i check magnets on pertronix also Edited November 11, 20213 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631394 Share on other sites More sharing options...
November 11, 20213 yr Author comment_631396 here is one feeler gauge video. Soo...i may have done the pressure test wrong. I removed 1 plug at a time and did each cylinder. Should i have removed all of the plugs and done the test? IMG_2954.m4v Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631396 Share on other sites More sharing options...
November 11, 20213 yr comment_631398 On 11/11/2021 at 3:02 PM, Wally said: sprayed fluid in carbs What fluid did you use? Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631398 Share on other sites More sharing options...
November 11, 20213 yr Author comment_631399 On 11/11/2021 at 9:13 PM, Zed Head said: What fluid did you use? WD-40 Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631399 Share on other sites More sharing options...
November 11, 20213 yr comment_631400 Use something more flammable. Starting fluid, carb cleaner, hydrocarbon brake cleaner. Or gasoline. And make sure it gets past the pistons in the carbs in to the runners. Edited November 11, 20213 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631400 Share on other sites More sharing options...
November 11, 20213 yr comment_631401 Use this stuff for starting. It's the cheapest you'll find. Link to comment https://www.classiczcars.com/forums/topic/65981-car-will-not-start/?&page=6#findComment-631401 Share on other sites More sharing options...
