Center Panel
MikeT73
  • 3 months later...
Mike ...you don't state the year but the early ones have all the cables from the heater controls running to the various flaps and heater controls attached at the opposite end under the dash (at the core area) under the dash. You must disconnect these first to pull out the panel. I think here is also one screw on the bottom portion that attaches just behind the cigarette lighter. It's been awhile since I pulled mine. You will also have to detach the electrical wiring from the light at the top of the panel. Good luck.
