November 19, 20213 yr Author comment_631868 Only reason I took it apart was because the coolant was complete dried up wanted to make sure the jackets were good. One of the head bolts had a little rust next to a coolant jacket. So I’ll just clean it up maybe get some head work done for breathablity and keep the stock efi system and an electronic distributor call it reliable 190 hp 👌🏽👌🏽 Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631868 Share on other sites More sharing options...
November 19, 20213 yr comment_631869 Be careful with modifications on the factory EFI. It doesn't tolerate that well. I agree with cleaning it up and regasketing it Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631869 Share on other sites More sharing options...
November 20, 20213 yr comment_631891 4 hours ago, Patcon said: Be careful with modifications on the factory EFI. I keep hearing that. Do you know the source for that sentiment? The original source? Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631891 Share on other sites More sharing options...
November 20, 20213 yr comment_631899 I dont think I have an original source. I would base that on people in the past who have tried to modify but can't get fueling correct. Vendors, especially cam vendors have also expressed similar sentiments. Only supplying relatively mild cams for the factory efi. The fuel mapping is so primitive. When the modifications require more fuel it's hard to provide, especially if the required fuel is not even across the board. Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631899 Share on other sites More sharing options...
November 20, 20213 yr comment_631903 I remember a guy on Hybridz that did a lot of testing and wrote an instruction on how to tune the standard L28 efi system. His conclusion was the standard efi manifold was your biggest challenge to improving the horsepower performance. He measured the internal diameter of the runners and his conclusion was the runner were somewhere around 55% of the intake valve. The N42/47 being maginally worse than the P82. The turbo manifolds being slightly better. I don't think he was saying the efi system was not tunable, just the intake manifold was already at its limit and would limit the benifit of any "more than moddest" modifications. I think he went by the naame Braap on Hybridz, but it's going 10 years back. I think I coppied the tutorial he wrote. I'm on holiday atm, can't seem to find it on my tablet. Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631903 Share on other sites More sharing options...
November 20, 20213 yr comment_631907 15 hours ago, 280zdude said: The car only has 58k miles on it so I was really concerned haha The pic i put above is of a 280zx block with only 74k Miles (120kkm) so your cylinders should be even better than mine. (My car had oil stickers (MOBIL1 ) even in the door so i think... that it had good maintenance.. the PO was a garage and a RDW guy.. something like someone that worked professionally with cars and knows alot of the subject.) R.D.W. rijks dienst wegverkeer.. Sort of a very technical Dutch DMV? they do APK (= like a MOT.) Also they decide what cars and other mobile stuf is road legal. Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631907 Share on other sites More sharing options...
November 20, 20213 yr comment_631921 My limited experience with new rings in an old bore was years ago. I cleaned the cylinders (that still had light cross hatching), used the original pistons with new moly rings. That combination worked well for another 20+ years as a daily driver. I'd do it again. Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631921 Share on other sites More sharing options...
November 20, 20213 yr comment_631923 7 hours ago, EuroDat said: I remember a guy on Hybridz that did a lot of testing and wrote an instruction on how to tune the standard L28 efi system. His conclusion was the standard efi manifold was your biggest challenge to improving the horsepower performance. He measured the internal diameter of the runners and his conclusion was the runner were somewhere around 55% of the intake valve. The N42/47 being maginally worse than the P82. The turbo manifolds being slightly better. I don't think he was saying the efi system was not tunable, just the intake manifold was already at its limit and would limit the benifit of any "more than moddest" modifications. I think he went by the naame Braap on Hybridz, but it's going 10 years back. I think I coppied the tutorial he wrote. I'm on holiday atm, can't seem to find it on my tablet. This might be it? Enjoy your Holiday. Just a few more days for me. https://forums.hybridz.org/topic/95316-braaps-l6-efi-induction-advice-and-tips/ "The OE EFI will NOT tolerate larger than stock cams, (large enough to make any difference one would spend money and time to swap out), and there is no “reasonable†way around it. If you desire a cam for EFI L28, do yourself a favor and steup to aftermarket Engine management which will allow you to tune around the new VE curve the cam delivers and also delete the AFM from the air stream. The stock Z car EFI isn’t tunable enough to compensate for an altered VE curve. I’m sure someone could hack the resistors and caps in the ECU, but with Mega Squirt being so inexpensive and readily accessible now… The OE EFI will barely tolerate extreme exhaust mods and minor head work, (those two items with the stock cam and stock EFI intake manifold don’t alter the VE curve too much and what they do alter we are able to compensate for with a variety of methods). The OE EFI will not tolerate freer flowing intake manifolds. Both of those alter the VE curve drastically enough that there is no reasonable way to keep the part throttle cruise AND WOT in balance. You will have to sacrifice one for the other and at that, if you spend too much driving around in the compromised region of the tune, the tune could be far enough out to actually foul plugs, which means that when get back into region that is correct for the engine, it wont run right due to fouled spark plugs. In summation, if you have the stock EFI, keep the stock cam and stock intake manifold. If you desire an intake manifold and/or cam change be sure you also have an alternative engine management system that allows the end user to tune and make use of what the cam and intake manifold brings to the table in performance gains." Edited November 20, 20213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631923 Share on other sites More sharing options...
November 20, 20213 yr comment_631925 That was my understanding too. You could richen the whole range with a potentiometer but its highly unlikely to be good all across the range Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631925 Share on other sites More sharing options...
November 20, 20213 yr comment_631927 Yeah, I like his fix for the idle. Attack the AFM with a dremel to increae air flow at idle. And then fix the next problem you created when the AFM vane drops to low and cuts the fuel pump.... Edited November 20, 20213 yr by EuroDat Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631927 Share on other sites More sharing options...
November 20, 20213 yr Author comment_631938 Yeah I was reading about it. I’m guessing they need a longer duration if pulse. And more fuel pressure. I’m not 100% but I believe the pulse is in relation to the distributor. Anyways I’m sure there’s a way with adding resistors or something to length pulse. Or you can just put a ecu instead of trying to work it analog Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631938 Share on other sites More sharing options...
November 20, 20213 yr comment_631947 Find some carbs and you're good with a cut cam on these old cars. An aluminum flywheel and port match performance exhaust is the easiest thing to do for the money. I have a 10lb flywheel on mine and it's like riding a motorcycle without all the hospital, funeral bills. Link to comment https://www.classiczcars.com/forums/topic/66051-mirror-finish-on-piston-walls/?&page=2#findComment-631947 Share on other sites More sharing options...
