My new (to me) 73 240z behaves badly at idle and low speeds. It feels like a plug or two is fouled and missing. However, when I put my foot in it, things get better as if the fouled plugs clear themselves. Checks on the ignition system appear to show that things are normal, and there's no signs of obvious fouling on the plugs. So, I begin to wonder if it's carburation.
Details: 1973 240Z, Automatic. Dual point distributor, Dual 32/36 Weber DGVs, EGR intact but air pump belt is off.
It's been a number of years since I did serious engine work and I seem to have forgotten my diagnosis skills. Point me in the right direction?
Thanks,
-Jim Kirkpatrick
Walnut Creek, CA
https://www.classiczcars.com/forums/topic/6608-diagnosis-help/
Some things to consider. With your foot in it....full throttle, you will be at full advance in your distributor. I had a similar problem and discovered that the centrifical advance assembly was worn out and ran like crap at lower RPMs. Also, at full throttle the only circuits in your carbs that are working are the high speed circuits, so possibly the balance and or idle adjust screws may need adjustment, to achieve low speed and idle smoothness.
