2 hours ago, fixitman said:
I have (2) used aluminum brake drums. ID of each measure about 9".  They were painted black long ago and do not look pretty any longer.  Are these drums of any value to anyone?
Thanks,
Dave
If they can be turned on a brake lathe, and still be in spec, they are serviceable.
Otherwise they aren’t worth much at all.
I know they can be relined (it's expensive), but I thought someone was making new aluminum drums
Found:
https://whiteheadperformance.com/product/datsun-240z-260z-280z-oem-aluminum-rear-brake-drums-nos-2/
https://www.thezstore.com/page/TZS/PROD/24-5050A
So I would say out of spec is scrap metal. If they can be turned,  I would do that
Edited by Patcon
Found:
Both of those links say "Out of Stock"
If i take a close look at the pics... ( of whiteheadperformance) there is a steel drum in the alu drum/casing?  (they will last even longer?) So they are a remake?
Years ago i bought a set from someone that had a Datsun original set used on.. i believe the car brand was TVR?  He had only drilled the 4 boltholes a bit bigger and they fitted.. (I only have to fill it with some small rings to use it on a 240z again..)
If all the cooling fins are decent they can be reman. by whitehead i think maybe they are interested in some cheap old drums..
Yeah.. hadn't really thought about it..  btw  How do they renew them?  On a lathe and get all the steel out and put in a new steel liner?
I can imagine they take most out, and weld the new one in on the edge and clean the edge by putting it in a lathe and make a nice edge?
Heatshrinking could be a bit dangerous i think.. because these things can get very hot and the steel could come out the aluminium casing?
Maybe a bit of both?
