Posted December 18, 20213 yr comment_633285 Is the tank mount off center and the spare tire center? Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/ Share on other sites More sharing options...
December 18, 20213 yr comment_633286 On left hand drive cars, the tank is mounted off center towards the passenger side and the spare tire is off center towards the drivers side Edited December 19, 20213 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633286 Share on other sites More sharing options...
December 18, 20213 yr comment_633287 This might help in showing the amount of off-center for the spare tire well. Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633287 Share on other sites More sharing options...
December 18, 20213 yr comment_633288 Here's a post with actual measurements: Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633288 Share on other sites More sharing options...
December 18, 20213 yr comment_633290 2 hours ago, Patcon said: The tank is mounted off center towards the passenger side and the spare tire is off center towards the drivers side :polite cough: Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633290 Share on other sites More sharing options...
December 18, 20213 yr comment_633291 1 hour ago, HS30-H said: :polite cough: It's all relative, right? 😄 Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633291 Share on other sites More sharing options...
December 18, 20213 yr comment_633293 The thing that freaked me out was the day I discovered the hatch lock striker bar isn’t in the center of the slam panel. The release button up on the hatch deck is in the middle, but not the actual catch Sometimes we assume symmetry where none exists. Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633293 Share on other sites More sharing options...
December 19, 20213 yr comment_633320 11 hours ago, jfa.series1 said: It's all relative, right? 😄 Ah, but relative to Left and Right hand sides of the car, not 'Driver' and 'Passenger'... And of course, all this is Domino Effect. The fuel tank is offset to the Right hand side because the exhaust is on the Left hand side of the car, because the exhaust manifold is on the Left hand side of the engine. Design Concession in action. Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633320 Share on other sites More sharing options...
December 19, 20213 yr comment_633321 2 hours ago, HS30-H said: Ah, but relative to Left and Right hand sides of the car, not 'Driver' and 'Passenger'... And of course, all this is Domino Effect. The fuel tank is offset to the Right hand side because the exhaust is on the Left hand side of the car, because the exhaust manifold is on the Left hand side of the engine. Design Concession in action. I was originally going to reference left and right but was concerned that might cause confusion based on whether they knew that was based on looking from the rear of the car Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633321 Share on other sites More sharing options...
December 20, 20213 yr comment_633377 We could go to what Mariners use... Port = Left side of car when looking to the front of the car from the rear and Starboard = Right side of car when looking towards the front of the car from the rear. 🤪 Link to comment https://www.classiczcars.com/forums/topic/66162-wheelwell/#findComment-633377 Share on other sites More sharing options...
